Can Windows language settings affect screensets?
Re: Can Windows language settings affect screensets?
Postby ger21 » Wed Mar 15, 2017 12:47 pm
I'll ask him to change back to Korean, and see if the error still persists.
Postby ger21 » Fri Mar 17, 2017 2:05 am
He said it still won't work with the Korean language. And it's not a font issue, as he can use the Arial font with the Korean language. But when he changes back to English, it works fine.
Postby cncdrive » Thu Mar 23, 2017 12:16 am
Gerry, the version 1.2036 UCCNC which I've just uploaded now prints the screenset error on the message window, so you may ask the customer to try run this and make a printscreen of the error message, so we could have a better idea about what the issue is with the Korean Windows.
Postby ger21 » Thu Mar 23, 2017 10:33 am
I'll let him know and see if he can try it.
Postby ger21 » Mon Mar 27, 2017 11:02 pm
Here's the error message.
He says that the translation is "constant has a newline character".
Postby cncdrive » Tue Mar 28, 2017 3:58 pm
Hi Gerry,
I studied the error message and your screenset code and I think I probably found what the problem is.
I think the Korean Windows can't read the ° character for some reason from your screenset file.
I've attached a printscreen of this part of the screenset code, and the Line of error is 1902, but there is a 5 lines offset between the line numbers and what the compiler gives,
because there are 5 lines of code which is the class definition before, where the screenset code is copied.
So, the line 1897 (which is the line 1902 for the compiler) has the °character in the string and it seems this is the first occurance of this character in the string in the screenset file.
Could you please try to remove all the °characters from the string parameters and ask the customer to test it.
If he will confirm that this resolve the issue then I will try to read after why the issue is happening with the Korean Windows and will try to provide a solution.
