How to configure spindle's thermal switch
Postby steverosburg » Mon Dec 02, 2024 5:44 pm
I just replaced my water cooled Chinese spindle with a Mechatron Professional series spindle that has a built-in thermal switch. The power harness includes a couple of wires which can be integrated into my controller, but I'm not sure the best way to do so. I have an AXBB-E and a 3-axis machine, so I'm currently using isolated inputs I1, I2 and I3 for the limit switches and I4 for the probe, which leaves inputs I5 and I6 available.
Assuming I connect the wires coming from the thermal switch to the I5 input, how would I configure the UCCNC software accordingly?
Thanks in advance!
-Steve
steverosburg
Re: How to configure spindle's thermal switch
Postby cncdrive » Mon Dec 02, 2024 10:36 pm
You could use the Fault signals plugin and configure that termal switch input as "Stop" or "Reset".
Postby steverosburg » Tue Dec 03, 2024 3:35 pm
Thank you, that's very helpful. So, I assume I would wire the leads through my 24V power supply like I do with the limit switches, and if/when the circuit completes it will trip the fault?
steverosburg
Postby cncdrive » Wed Dec 04, 2024 9:51 pm
Yes, sure, wire it the same way as you wire any other signals, like a limit switch or home switch.
Yes, if you configuring it in the fault plugins then it will call the function you assigned, e.g. a Stop or Reset function.
Postby steverosburg » Fri Dec 13, 2024 5:39 pm
This works like a charm, thank you!
steverosburg
