Screenset2022- Cannot change settings
Postby SRHEAUME » Fri Aug 16, 2024 3:15 pm
Hi
I have been using Screenset2017 for a while and decided to upgrade to Screenset2022 (Redownloaded => 2022_Screenset_V1.015.exe)
My problem is that I cannot change most of the settings. Example in probing/settings/Z Axis Auto Zero Settings, whatever number I enter the field return 0.
Other examples in most settings pages where there are checkboxes, I cannot check any of them and in addition no checkbox are shown (Kernel Frequency should have at least one checkbox checked but all blanks). Finally Z Auto Zero macro doesn’t run (no move) my probe is working as I it in the Diag. screen
Installed / deinstalled / Reinstalled many times even install as administrator but nothing works.
Thanks for your help
SRHEAUME
Re: Screenset2022- Cannot change settings
Postby mickecarlsson » Fri Aug 16, 2024 4:36 pm
Have you followed the install instructions? You need to enable the plugin. See page 3 of the installation document.
mickecarlsson
Postby SRHEAUME » Fri Aug 16, 2024 5:43 pm
For sure, as I said I did many install reinstall while rigorously following the doc :cry:
SRHEAUME
Postby mickecarlsson » Sat Aug 17, 2024 6:49 am
What version of UCCNC are you using?
mickecarlsson
Postby SRHEAUME » Sat Aug 17, 2024 3:36 pm
System Information
Software version: 1.2113
Hardware version: 1.0000 Firmware version: 1.0370 Serial number: CD11CC API version: 2.1820
Device type: UC300ETH_UB1
My hardware/software meet all the requirements.
Dell G16 7630 Laptop : i9-13900HX 2.20 GHz RAM 32.0 GB with Win11
Screenset 2022 : Downloaded 2022_Screenset_V1.015.exe
SRHEAUME
Postby SRHEAUME » Sat Aug 17, 2024 3:39 pm
My remaining problem is that I cannot change any of the probing settings. Example in probing/settings/Z Axis Auto Zero Settings, whatever number I enter in the field , it always return 0. Same thing for all other fields.
Therefore I cannot do Probing
My probe is functioning properly as shown on the Diagnostic page and on LED of the Run page.
Also, probably related, the Z Auto Zero button does not function => no movement of Z Axis and is giving me the message :
Probing move completed without triggering input.
If no contact was made, increase Probe Distance and try again.
If contact was made, verify that probe input is functioning properly.
Therefore I cannot use my router, tried to use Screenset 2017 but it cannot drive the VFD spindle (Plugin: HYPLGIN14)
Note: The VFD spindle with the HYPLGIN14 plugin is working ok with the Screenset 2022
SRHEAUME
Postby mickecarlsson » Sun Aug 18, 2024 6:58 am
Start UCCNC, go to Settings -> Page 2, click on Configure Plugins.
Make sure that 2022 Screenset is ticked on Call startup and Enabled:
mickecarlsson
Postby Synthesis » Sun Aug 18, 2024 3:19 pm
I am also encountering this issue (first post here), but while typing this post up and recording the screen for a video example of the issue, I believe I may have discovered the root cause:
When clicking in a text field within the Z Axis Auto Zero Settings, my on-screen keyboard pops up with the numpad style keyboard, as I am using an ELO industrial touchscreen and do not have a keyboard attached to the PC running UCCNC. I *do* have a remote window into the PC from my main desktop, so most of my configuration has been handled remotely.
If I enter a value in here and click Enter, I get a big fat zero for the text entry, no matter what I put in.
But:
If I hit escape out of the on-screen numpad, then when I enter a value, it shows the value, and I am able to click Save Settings/Apply Settings without issue.
I can do this both locally with a keyboard plugged in, and remotely from my main PC... In both cases, closing the on-screen keyboard and then entering the value using a keyboard seems to be the fix for me.
Synthesis
Postby SRHEAUME » Sun Aug 18, 2024 6:06 pm
Problem was so weird that I decided to do a complete reinstall of UCCNC and Scfreenset2022.
Now it works normally ;)
SRHEAUME
Postby ger21 » Mon Aug 19, 2024 1:38 am
Glad you got it working.
Your original post about the check boxes and auto zero not working were due to the plugin not being enabled, as all the checkboxes are handled buy the plugin.
The issue with the Fields not accepting values is really not a screenset issue, which is why I suggested a clean install. The screenset has nothing to do with the handling of values entered into the fields.
