Plugged the 24v PSU into the 5V IN/OUT on the board by mistake, snap, crackle, pop and smoke came out.
Just wanted to see if there's anything I can do with this board other than throw it?
poppyseeds wrote:so could i still use this board or would I need to get this cheap replaced somehow in order to use it again?
fsli wrote:poppyseeds wrote:so could i still use this board or would I need to get this cheap replaced somehow in order to use it again?
You cannot use the AXBB-E without getting the chip replaced. If you don't have the skills yourself, you should determine the cost to have it repaired vs throwing it away and buying a new board. I don't know where you'd go to have it repaired, though.
Users browsing this forum: Majestic-12 [Bot] and 20 guests
