Can't set pins for limit switches
Postby MeatGrowler » Wed Mar 22, 2023 4:53 pm
Hi All,
I'm just setting up everything to do some bench testing. I have 1 motor turning (Z axis) so far. I have also wired in a proximity sensor (NPN NC) using pin 12. The LED responds as it should, as does the software. The problem I'm having is when I come to assign the limit switch to the Z axis. When I fill in the boxes with pin 12, it keeps reverting back to empty boxes. Am I missing something?
MeatGrowler
Re: Can't set pins for limit switches
Postby ger21 » Wed Mar 22, 2023 6:03 pm
Are you hitting enter after typing in the number?
Postby MeatGrowler » Wed Mar 22, 2023 6:36 pm
I have just tried, but no joy.
They are all set to 0 to begin with, I change the pin to 12 and the port to 2. But as soon as I click apply or save settings they both jump back to 0.
MeatGrowler
Postby ger21 » Wed Mar 22, 2023 6:44 pm
What controller do you have. Is pin 12 port 2 an input or output?
Postby MeatGrowler » Wed Mar 22, 2023 6:47 pm
Oops I forgot to say, it's the AXBB model.
MeatGrowler
Postby MeatGrowler » Wed Mar 22, 2023 9:20 pm
Solved. That's i2 isn't it, not 12 :? A trip to Specsavers might be in order :D
Thanks for the help
MeatGrowler
Postby ger21 » Wed Mar 22, 2023 11:24 pm
Your not the first to make that mistake. :lol:
Postby cncdrive » Sat Mar 25, 2023 3:48 pm
Yes, we just changed the stickers, removed the I characters before the i/o numbers.
