Fusion 360 code is jerky..
Postby dimmaz88 » Mon Mar 13, 2023 6:37 pm
Hi all, as the title suggests really. I don't often use Fusion for CAM so I've not had to deal with this issue, but I have job coming up and it needs addressing.
I noticed the issue recently when cutting an adaptive pocket, it basically spirals out from the centre. The curves are a really jerky movement and I had to stop it.
I don't have the same issues when using Aspire.
Here's the processed code (deleted the majority in order to meet character limit)..
(fusionAdaptive)
(T2  D=6. CR=0. - ZMIN=0.5 - flat end mill)
G90
G53 G0 Z0.
(Adaptive1)
T2 M6 (flat end mill D=6. End Mill 6mm Single Flute (Acrylic))
S16000 M3
G64
G54
G43 H2
G0 X-126.918 Y-129.398
Z35.
Z25.
Z22.5
G2 X-129.397 Y-133.082 Z21.63 I-3.081 J-0.603 F333.3
X-129.975 Y-133.14 Z21.528 I-0.603 J3.081
X-133.123 Y-130.042 Z20.658 I-0.025 J3.123
X-133.074 Y-129.466 Z20.556 I3.123 J0.025
X-129.468 Y-126.957 Z19.686 I3.057 J-0.548
X-128.915 Y-127.11 Z19.583 I-0.548 J-3.057
G0 Z35.
M5
G53 G0 Z0.
M30
Any help appreciated.
dimmaz88
Re: Fusion 360 code is jerky..
Postby ger21 » Mon Mar 13, 2023 7:46 pm
Loosen up your CV tolerance settings.
Postby dimmaz88 » Mon Mar 13, 2023 8:10 pm
Hi Gerry, is this done in UCCNC? I haven't ever changed it so what would be a good amount to change by?
dimmaz88
Users browsing this forum: Google [Bot] and 22 guests
