Connection to UC300ETH-5LPT Windows 10
Postby r.hoffmann » Thu Feb 16, 2023 7:52 pm
I got a new PC with Windows 10.
If Im setting it up like in the that manual I get an Error when testing the connection.
Is there an other way to make the Network connection work under Windows 10?
r.hoffmann
Re: Connection to UC300ETH-5LPT Windows 10
Postby wmgeorge » Thu Feb 16, 2023 10:39 pm
As that screen is telling you its set up wrong. I had zero issues when did mine two weeks ago. Follow the instructions step by step and it works. I needed a cross over cable but it still was connected.
wmgeorge
Postby cncdrive » Fri Feb 17, 2023 12:16 am
You have to set the network adapter IP address to 10.10.10.10 and not to 10.10.10.11.
Postby wmgeorge » Fri Feb 17, 2023 12:38 am
I was going to suggest he use the Windows Snipping Tool and post those instead of picture of the screen.
wmgeorge
Postby r.hoffmann » Fri Feb 17, 2023 2:06 pm
Thank you! It works!
r.hoffmann
Users browsing this forum: Google [Bot] and 7 guests
