wiring diagrams/input help
Postby Moe » Tue Feb 14, 2023 11:25 pm
hello all, my name is Moe first time controller builder here, so please forgive my lack of knowledge. im teaching myself.
i have the UCSB and the uc100.
im having a hard time when it comes to the inputs.
i cant seem to figure out the limit switches, e-stop, and prob
outputs i got. flood and mist all working.. but these darn inputs got me.
limit switches are NC and there are 3 of them x,y,z. the prob for now is just for tool height. so it just has 2 wires.
if i could see examples or diagrams. i feel i could figure it out.
thanks for any help giving. and sorry for what im sure has been asked a lot. but i could not find what i was looking for when i search this forum.
owner/operator/ and everything else
https://www.addisonindustries.net
Moe
Re: wiring diagrams/input help
Postby Moe » Wed Feb 15, 2023 7:33 pm
pics are for the probe wiring
probe 1 pin:13 port 1 active low is checked
Moe
Postby Moe » Wed Feb 15, 2023 10:43 pm
does the wiring look right for the NC limit switches I10 - I12
x axis
limit + pin 10 port 1 active low checked
limit - pin 10 port 1
y axis
limit + pin 11 port 1 active low checked
limit - pin 11 port 1
z axis
limit + pin 12 port 1 active low checked
limit - pin 12 port 1
Moe
Postby Moe » Thu Feb 16, 2023 2:05 am
this is what i have right now i get 24v at SW and at the ucsb. but i have no lights on the Input LED's
Moe
Postby Moe » Fri Feb 17, 2023 5:48 pm
thanks for all the help and input on letting me know what im doing wrong.
Moe
Postby wmgeorge » Fri Feb 17, 2023 6:08 pm
Trying to remember how I did mine, its like the diagram in the PDF. I believe all the (-) on the Pins used went to (-) on the PS and the (+) came from the PS and through the switches and back to the (+) of the Pins used input. Mine had all the Limits in Series to one Input except for A drive motor same for Home all except for A which makes the Y and A motors sync together. A stepper motor is Slave to Y axis motor.
wmgeorge
Postby Moe » Sat Feb 18, 2023 7:24 pm
wmgeorge wrote:Trying to remember how I did mine, its like the diagram in the PDF. I believe all the (-) on the Pins used went to (-) on the PS and the (+) came from the PS and through the switches and back to the (+) of the Pins used input. Mine had all the Limits in Series to one Input except for A drive motor same for Home all except for A which makes the Y and A motors sync together. A stepper motor is Slave to Y axis motor.
thank you George for some info. ill keep poking at it till i get it right.
Moe
Postby wmgeorge » Sat Feb 18, 2023 7:37 pm
I don't understand your showing connections to a ribbon or other type of connector, mine works as I have described.
wmgeorge
