UCCNC Lasersettings with Uc300eth and Triple beast
Postby Vikilaser » Sat Feb 11, 2023 3:14 pm
Im using the UCCNC-software together with a triple beast and a Uc-300eth 5LPT.
Which settings I have to do, to use a laser correctly?
It would help me when anybody Could check my connections on my pictures below. Hopefully anybody can sent me pictures from his settings.
I really need specifical help for my situation/wiring...
On the driver board from my laser are two LEDs. One red LED is for showing powersuply is correctly wired. And one green LED is for showing pwm Signal is wired correctly.
Both LEDs are on.
My connections:
Triple beast via LPT flat wire to port 2
Laser Ground to Uc-300eth in analog port pin5
Laser Pwm Signal to Uc-300eth on analog port pin6
My question is about the settings in UCCNC. Have l to set something, to use the analog Port?
I want to Switch the laser on and off with M10 Q... and M11 Q... comands.
Something must be missing in my settings for my laser dont reacts to the comands.
If anybody can check my wiring sent pictures specific for my wiring that would realy help me, for my knowledge in electronics are bad.
Thank you
best regards
Viktor
Vikilaser
Re: UCCNC Lasersettings with Uc300eth and Triple beast
Postby Vikilaser » Sat Feb 11, 2023 3:18 pm
Here is the driverboard with the Leds.
Vikilaser
Postby Vikilaser » Sat Feb 11, 2023 3:24 pm
Here is a picture from the complete wiring.
Vikilaser
Postby Vikilaser » Sat Feb 11, 2023 3:31 pm
Vikilaser
Postby Vikilaser » Sat Mar 11, 2023 6:57 pm
My conection was false. I had to conect the laser pwm to a normal Port not analog.
Vikilaser
