Z-offset after tool change wrong
Re: Z-offset after tool change wrong
Postby CADdy » Sat Feb 04, 2023 12:51 am
and which is now the correctly working M31 macro? Is the one from version 1.2115 ok?
Peter
CADdy
Postby Parkgrr » Thu Feb 09, 2023 10:55 am
Hi Peter, I'm still just using Terry Parker's M31. I can't use the default M31 as I'm using a rotary ATC. I copied/pasted the exact code mentioned before from the default M31 to mine to do the actual touch off and write the offsets and it just doesnt. Not sure what I'm missing
Parkgrr
