Engraving with 6W Laser - Heavy burn spot at start and stop
Postby Samarah » Tue Feb 07, 2023 2:57 pm
I recently added a 6W Opt laser to my Avid PRO CNC router. The router was converted to a UCCNC 300UCETH controller from the as-built Mach3/Smoothstepper. The laser seems to function properly, but I am experiencing a heavy burn spot at the start and stop of segments while engraving. I am assuming it is a dwell issue for the spindle spin up. I am arming the laser with M03 and using M10 Qx to control the laser power. I played around with the M03 delay but that didn't seem to make a difference. Any suggestions would be greatly appreciated.
Samarah
Re: Engraving with 6W Laser - Heavy burn spot at start and s
Postby Samarah » Fri Feb 10, 2023 5:54 pm
Fixed my problem by setting the dwells to zero and adding the following to the post...
+ Commands output when the jet is turned on
begin JET_TOOL_ON
"M03"
"M10 [P]"
+ Commands output when the jet is turned off
begin JET_TOOL_OFF
"M11"
"M05"
Samarah
Users browsing this forum: Google [Bot] and 22 guests
