AXBB-E 24V Supply Too High?
Postby Joepayne1 » Thu Jan 19, 2023 8:37 pm
In the process of converting a Boxford 190VMC and am going to use the existing 24V supply to power the AXBB-E.
I measured the supply across the capacitor and it reads 27.4V. Is this likely to fry the board? If so, how do I go about reducing this voltage to make this compatible? Completely new to electronics so go easy!
Joepayne1
Re: AXBB-E 24V Supply Too High?
Postby cncdrive » Fri Jan 20, 2023 7:40 pm
Up to 30Volts it should be fine.
Postby cncdrive » Fri Jan 20, 2023 7:41 pm
Up to 30Volts it should be fine "by design", but we did not test it with more than 24Volts.
Postby fsli » Sat Jan 21, 2023 2:18 am
Joepayne1 wrote:how do I go about reducing this voltage to make this compatible?
https://www.amazon.com/Stabilizer-Prote ... VHX8/?th=1
Frank
fsli
Postby cncdrive » Sat Jan 21, 2023 10:47 am
Or put a few diodes in series, they drop a fraction of volts, e.g. 0.6V drop per diode for a standard type diode.
Postby Joepayne1 » Sun Jan 22, 2023 5:28 pm
Thanks for your replies. I will investigate both options as I would like to keep it to 24v.
Joepayne1
