GCode formula
GCode formula
Postby DavidT » Sat Dec 31, 2022 5:05 pm
The M17 macro set the variable #3 to either 0.0 or 0.5.
I can't figure out how to use it in GCode formula.
#3 = 0.0
M17
G00 Z80.000
G00 X10.000 Y10.000
G01 X10.000 Y10.000 Z[8.000+#3] (brackets are not interpretable(they, and everything in it, appear in red in the GCode viewer))
G01 X10.000 Y10.000 Z[#3+8.000] (same as above)
G01 X10.000 Y10.000 Z#3+8.000 (will ignore the +8.000)
G01 X10.000 Y10.000 Z8.000+#3 (will ignore the variable)
I fear I have to recalculate the Z value for each and every line.
Something like:
#103 = Zcoord + #3
G01 X10.000 Y10.000 Z#103
Is that right?
Cheers
DavidT
Re: GCode formula
Postby dezsoe » Tue Jan 03, 2023 9:56 am
Yes, you are right.
Re: GCode formula
Postby DavidT » Sat Jan 07, 2023 9:00 pm
Thank you dezsoe.
So far, everything seems to work properly with this method.
The GCode is a bit harder to read, the file size is practically doubled but hey! if it works!? Let's carry on!
Cheers!
DavidT
Re: GCode formula
Postby DavidT » Tue Mar 28, 2023 10:43 pm
Hi!
I've been using the previous solution and it works fine but I know encounter the problem that if I merge various GCode together and separate them by M00 (wait for operator to Cycle Start before continuing), the value of #3 is lost ... from what I can understand, it is set to 0 after the M00.
Is there a more robust way to set a variable?
For now I just ask the question again every time I pause but it's redundant and there's a risk of error (if the operator makes a mistake when retyping in the value).
Thank you
DavidT
Re: GCode formula
Postby dezsoe » Wed Mar 29, 2023 8:16 am
M0 (or any other internal command) will not zero any variable, so check your g-code, there must be a line that changes it. Also, if you call macros or you have any macroloop then check them.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 5 guests
