Version upgrade and custom profiles
Postby bhdavis » Fri Nov 25, 2022 2:33 pm
If I upgrade from Ver. 1.2111 to Ver. 1.2113 will I be able to retain my custom PROFILE and SCREEN ? I ask because the example of Ver. 1.2113 shows a completely different screen from the older version screen which I've heavily customized to my purposes.
BH
bhdavis
Re: Version upgrade and custom profiles
Postby ger21 » Fri Nov 25, 2022 4:52 pm
If you have a custom profile with a unique name, then nothing will change when you upgrade.
The Default profile WILL change, though.
Also, there will likely be new settings that won't exist in your custom screen. This usually does not cause any issues, but sometimes a new setting will be enabled that you don't want.
SO, it's a good idea to look through the new default screen and see if there are any settings controls that you want to add to your custom screen.
Postby bhdavis » Fri Nov 25, 2022 5:20 pm
Thanks Gerry.
BH
bhdavis
Users browsing this forum: Majestic-12 [Bot] and 14 guests
