No Limit Switch
No Limit Switch
Postby Edi_48 » Sun Nov 06, 2022 12:55 pm
Hello I have 3 limit switches on my machine. When setting up the machine in Axis Setup,
at the Y-axis made in the Calibrate Axis the test in 100mm . When I manually enter Y -100 in the MDI G00, my machine goes back and full on the limit switch and overruns it. When I look in Diagnostics afterwards, the LED at port 10 is off.
I installed a new limit switch and moved the Y axis by hand.
Question: Why did the limit switch not react?
Edi_48
Re: No Limit Switch
Postby dezsoe » Sun Nov 06, 2022 6:23 pm
None of the UCxxx controllers has 10 ports, so I assume that it is pin 10. When you enter the port/pin number then press the enter key and Apply or Save. Go to the diag screen, trigger manually the limit switch and check the input and in the I/O function box the limit states.
Re: No Limit Switch
Postby Edi_48 » Mon Nov 07, 2022 9:16 am
Hello Sorry
I meant pin 10 port 1
I have checked all 3 limit switches in the diag. screen no reaction
Edi_48
Re: No Limit Switch
Postby dezsoe » Mon Nov 07, 2022 10:12 am
If the input works and the limit states don't then the limit input is not set. Check again and don't forget to apply or save. Which controller do you use?
Re: No Limit Switch
Postby Edi_48 » Mon Nov 07, 2022 1:10 pm
Hi my hardware is a UC400ETH+UCSB
Edi_48
Re: No Limit Switch
Postby dezsoe » Mon Nov 07, 2022 2:10 pm
OK, then port 1 pin 10 is an input pin, it must work.
Re: No Limit Switch
Postby Edi_48 » Mon Nov 14, 2022 10:02 am
Hello
When I move my axle and activate the limit switch
The machine should stop. However, my machine continues to move.
Hilton
Edi_48
Re: No Limit Switch
Postby Dazp1976 » Mon Nov 14, 2022 10:27 am
Edi_48 wrote:Hello
Hilton
Have you got the wiring right?. I'm only really used to npn ones.
If they're 3 wire npn type sensors the Black is normally the input, Blue is power GND, Brown is power +ve.
Black/Blue mixed up?.
Dazp1976
Re: No Limit Switch
Postby Edi_48 » Mon Nov 14, 2022 4:37 pm
Normal limit switch 2 adrig
When I operate them manually I see the switch flashing in diag
Hilton
Edi_48
Re: No Limit Switch
Postby dezsoe » Mon Nov 14, 2022 4:49 pm
Where do you see them? In the I/O monitor or the I/O functions monitor frame? If you see them only in the I/O monitor frame then the inputs work fine but the limits are not set to use these inputs (on the axis setup pages).
