UC300eth Help!!!!
UC300eth Help!!!!
Postby hacker77 » Mon Aug 22, 2022 11:21 pm
I recently purchased a C94 board with the UC300eth from CNC4PC. The issue is when I turn on machine, I reference all axis's then turn on Soft Limits. X & Y move without issues but the Z axis is weird. After I move all axis to cut position and try to
move Z in the NEG DOWN position so I can Zero it out, it immediately goes to the top of its stroke by limit switch. But if I turn soft limits off Z axis works fine up and down. How I know it has something to do with the UC300eth is I can take the same computer connect it to my old CNC machine with a Gecko G540 controller with a parallel port and everything works as it should including the soft limits. Also my Xbox controller will only move my Machine 31IPM , no faster. I'm using the Joypad PLUGIN from Mach 3 website. Now It work's fine on my Gecko G540 machine. I found a post with something similar to what I'm describing and someone suggested to go back to .013 Plugin. I'm currently using Windows 7 64 bit Desktop Running MACH 3 Version R3.043.066 I think there is a bug in the UC300ETH plugin maybe. Anybody experience this issue?
Any Help on this issue would be GREAT as I'm going CRAZY trying to figure this out.
Thanks Richard
hacker77
Re: UC300eth Help!!!!
Postby hacker77 » Thu Aug 25, 2022 3:10 am
Anybody with any info???
hacker77
Return to Mach3/4 Discussions
