by Parkgrr » Sat Jan 08, 2022 10:03 am
I do long ~20 hr cuts. UCCNC consistently throws this error when I'm doing a long cut, usually after many hours of cutting (10-15+). Nothing out of sorts happens with the hardware. Power supply to the UC300ETH, voltage, and temperatures are nominal. Everything is normal but this is thrown. I am using a network switch, I would suspect the switch except nothing else going through that switch fails inc internet connection. This has also happened after the machine has been 'on' for long periods but not running programs as well, but more rarely.
- Attachments
![Screenshot 2021-08-26 162210.png (180.68 KiB) Viewed 6053 times Screenshot 2021-08-26 162210.png](./download/file.php?id=3676&t=1&sid=0c28444b13c5107a9648d1ca6c865077)
