AXBB-E Mach3 Set up
AXBB-E Mach3 Set up
Postby cubsfan1953 » Sun Sep 26, 2021 12:30 am
I changed out my Chinese made Controller to this AXBB-E,, Been trying to get it to work for a week now,
My Ethernet on Computer is configured as : 10. 10. 10. 10. Submask: 255. 255. 255. 0.
The Blue Light comes on, The 24 v light is on and the 5v, Three LED's in a row are all lit.
The LED by the Ethernet plug is blinking at a fast pace,
I run the Utility Program, it shows that Communication is working,
But I have NO MOVEMENT Not anything from X Y OR Z Axis,,
I have Looked and read the manual till I'm Cross Eyed,,
Anyone have any idea's? Only Reason I changed is because I added a Laser to my Machine, Now I screwed Everything up,,
Thanks for any assistance,
Cubs :?
cubsfan1953
Re: AXBB-E Mach3 Set up
Postby ger21 » Sun Sep 26, 2021 3:25 am
Did you configure all your ports and pins and enable your axes?
Postby cubsfan1953 » Sun Sep 26, 2021 3:36 am
Gerry, I'm Not sure how you Configure These Ports and Pins with this Controller,,
You mean in Mach3 Right? I have Tried Everything I know to do,, Yes the Axis's are enabled, And the Motor tuning is just Standard at this Point,
I just cant even get a grunt, LOL
cubsfan1953
Postby cncdrive » Sun Sep 26, 2021 3:55 am
Check the kernel frequency setting in the AXBB-E plugin in the Plugins configuration in Mach3.
Try to set it to the lowest 25kHz first, because the default 100kHz might be too much for your drives.
If it is still not working then please show us your connections to let us see and verify them.
Postby MVPAWARDS » Wed Sep 04, 2024 9:54 pm
Did you install the UCX00SETUP.EXE This is needed for your machine to run with MACH 3 using AXBB-E
MVPAWARDS
Users browsing this forum: Google [Bot] and 10 guests
