Hello
I have been using Vcare Pro 6.5 for many years. I originally was using Mach3 on a Windows XP desktop. I wanted to upgrade to another platform and use my Win10 laptop. I decided to use Uccnc software and a UC100 controller. I have these products up and running on my cnc machine. My cnc machine is a off brand so I don’t know the configuration, however, it has a Rockcliff control board. For a test I created a 4” square. The problem is that when I use my older Vcarve Pro version 6.5 and import the part to the Uccnc software the overall dimensions are about half the size (2 inches square ). And my cnc cuts it at 2 inches.
I down loaded the newest Vcarve Pro 11.0 free software and I used the training file “Bull head sign”. When I send the job to the Uccnc software it is now showing the part with the correct size (i.e. 4” wide and 11 inches long) but the Cnc is still cutting out the work about how alf the size (2” wide and 4 inches long). I tried all the available Gcode file extensions available but all have the same results. Has anyone seen this problem when using the Uccnc software? I want to purchase the Vcarve Pro 11.0 upgrade but I don’t know if any of the file extensions will work. I notice that the newer version has a Uccnc file extension loaded as an option. I just don’t know if that will work. Thanks for the help.
Thank you
