It's super easy. Just enable the plugin and restart UCCNC. If you show the plugin window then you can set some options:
- lightburn.png (5.84 KiB) Viewed 14744 times
If you tick Auto-convert then the plugin will watch for a fresh loaded file and check the first line. If it starts with "; LightBurn" then it converts the file for UCCNC and saves it besides the original file with "_UCCNC" added to the file name.
The Set minimum power option does what you think: instead of turning off the laser (while moving to new position) it sets a minimum value.
The Scale is the same logic. LightBurn outputs 0..255 to control the laser. You can override this to e.g. 30..200.
The 2 options above can be used together.
With the plugin button number you can assign a button code to show up the plugin window. (You place a button on the screen and set its buttonnumber property to this number.)
Don't forget to save your settings.
You may also choose to start the conversion manually: turn off auto-convert and press Load and convert file.
