WHB04B-4 Pendant Plugin
Re: WHB04B-4 Pendant Plugin
Postby Tobe91 » Tue Feb 02, 2021 8:30 am
Sounds cool, thanks for your effort! :D
Tobe91
Postby shad » Fri Feb 05, 2021 8:27 pm
Hello!
Please check attaching plugin.
WHB04BPendant.rar
(220.27 KiB) Downloaded 1036 times
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
http://neuroncnc.com/
shad
Postby Tobe91 » Sun Feb 07, 2021 8:20 am
Good Morning,
thanks for this new Version. I just checked with simulated profile in UCCNC and there it works mostly. I'm currently reworking my CNC control cabinet, so I think i'm first able to test it directly at the machine next weekend.
The plugin is now adjusting the multiplier when I change the knob on the pendant :)
Also its saving the entered speed multiplier value in the plugin config window!
But I have two open questions:
1) Is it possible that the maximum MPG speed multiplier value in the plugin config window is 20?
When I change the value in the plugin config window to 10 and restart the plugin, it's again showing 10.
When I change the value in the plugin config window to 50 and restart the plugin, it's showing 5 instead of 50.
2) It only changes the multiplier value if selecting 0.001, 0.01, 0.1 and 1.0. If I set the value to the 60% or 100% selection I think the multiplier doesn't change anymore compared to the 1.0 selection or?
Would it be possible to add even higher mulitplier values for the 60% and 100% selection?
Nevertheless thank you for this new version, that a big improvement for me :mrgreen:
Tobe91
Postby shad » Sun Feb 07, 2021 5:43 pm
Thank you for fast testing.
I am fixed the issue with MpgSpeedMultiplier. Now possible values from 0.01 to 25 and plugin check this values when you input new value too.
Not sure that it possible to change the multiplier value if selecting 0.001, 0.01, 0.1 and 1.0. This is a fixed values in UCCNC and in the pendant. Need to think about this more...
New version is attaching.
WHB04BPendant.rar
(230.5 KiB) Downloaded 1098 times
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
shad
Postby Tobe91 » Sun Feb 07, 2021 6:24 pm
Haa, that's looking now really good from my side :mrgreen:
Also I think it's good that the value is instantly reset to 25 if entering a value greater then 25.
Ok I thought it already selects a different speed multiplier if I select a smaller or greater value on the pendant, but if it's not I think it just applies the mulitplier to the selected step size or?
Would be interesting if it would be possible to add even faster jogging in MPG continous mode when selecting the 60%, 100% or Lead on the pendant with any kind of workaround. Especially for large CNCs would be nice to travel fast.
But nevertheless for me it's now covering almost all I needed, thanks!
Tobe91
Postby Greolt » Mon Feb 08, 2021 9:43 am
Andrew
First let me say that I very much appreciate that you have provided this plugin for UCCNC users.
It encouraged me to go buy a pendant.
Now a question out of left field. In the pic of my edited router screen you will see that I have reproduced the "Jog Feed %" controls on the front page.
I never use the jog panel. I like all my used features available on the front page.
When using the plus or minus buttons on either panel the percentage changes in both places as you would expect. All good.
However when turning the right hand dial on the pendant only the jog panel % changes, not the one on the front page.
If by any chance your code includes a line like, AS3jog.Setfieldtext("xxx", 913); would it be possible to add the next line, AS3.Setfieldtext("xxx", 913);
913 is the number of the "Jog Feed %" field
I am no programmer and do in no way want to tell grandma how to suck eggs.
So please excuse me if I am talking rubbish.
Thanks again, Greg
Greolt
Postby shad » Tue Feb 09, 2021 11:04 am
Not see any problem to make it.
Today try to make a changes and upload a new plugin.
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
shad
Postby shad » Tue Feb 09, 2021 8:33 pm
Ready.
WHB04BPendant.rar
(217.75 KiB) Downloaded 1068 times
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
shad
Postby Greolt » Tue Feb 09, 2021 8:57 pm
Andrew
That is amazing! I cannot thank you enough.
No one else will ever need this and yet you have done this version just for me.
THANK YOU
Greg
Greolt
Postby jpmreno1966 » Mon Mar 08, 2021 3:15 am
What is this plugin suppose to do? Is it suppose to help install this pendant?
jpmreno1966
