MODBUSEZ Plugin
Re: MODBUSEZ Plugin
Postby trendsetter » Sat May 04, 2019 4:02 pm
Dear all,
I have the following Inverter:
DZB312B003.7L2DK
manual is here:
https://www.manualslib.com/manual/82887 ... tml#manual
I am quite clear about setting the control of the VFD to Modbus and I have a standard USB-RS454 adapter.
It seems that there is some communication possible, since the display is changing with Modbusez plugin used with UCCNC but I cannot get the spindle running. The Spindle is still in Stop mode and I don´t have any chance to change it. Any tipps from the expert how to execly configurate the plugin for this Invertere?
Standard Analog digital control works perfectly, but I need more I/O therefore I want to change to modbus.
BR
Michael
trendsetter
Re: MODBUSEZ Plugin
Postby Paklic » Mon Sep 09, 2019 8:16 pm
I bought a VFD ecogoo 9100-1t-00150gb.
Manual I found here: https://pan.baidu.com/s/1hsw6eYo
I found how to set rs485 that's ok, but I don't know how to turn on rs485.
Does anyone know how?
Thanks...
sorry my english is not good.
Paklic
Re: MODBUSEZ Plugin
Postby Dan911 » Thu Sep 12, 2019 10:06 pm
Paklic go to page 1 of this thread and read how Battwell got his Ecogoo VFD working,
Re: MODBUSEZ Plugin
Postby Paklic » Fri Sep 13, 2019 10:28 am
Dan911 wrote:Paklic go to page 1 of this thread and read how Battwell got his Ecogoo VFD working,
but my problem is different, i can't enable rs485 is not comunication.
I have set up for rs485:
P9.00 is the local address / 1
P9.01 is baud rate - 9600/3
P9.02 is N81for RTU / 0
this setting is ok.
I don't need hex command
How to enable rs485 + and rs485-?
I can't do it from the read manual.
I got hex commands to be useful
[at
9100 RS485.docx
hex command
(19.21 KiB) Downloaded 1301 times
manual:
tachment=1]9100 User manual.rar[/attachment]
manual 9100
(1.95 MiB) Downloaded 1197 times
Paklic
Re: MODBUSEZ Plugin
Postby Paklic » Fri Sep 13, 2019 10:42 am
connected via modbus poll
Modbus not connection
Paklic
Re: MODBUSEZ Plugin
Postby v8kid » Thu Apr 09, 2020 7:23 pm
I must be dumb too because I went to P1 and couldn't figure out what the parameter settings were either!
Is Paklic correct that these are the only 3 parameters that require changing I assumed P0.01 P0.02, P0.16 and P0.17 require changing too.
Cheers
v8kid
Re: MODBUSEZ Plugin
Postby Battwell » Tue Apr 28, 2020 8:05 pm
re ecogoo. read pages 2,3,4 of this forum thread.
all the info and head scratching is there!
ecogoo was one of the easier ones to work out.
Re: MODBUSEZ Plugin
Postby cofhal » Mon May 18, 2020 8:13 pm
I am using screenset 2017.Install the MODBUSEZ16 plugin and I have a VDF Fuling DZB280 and everything works correctly, the only problem is that the speed I send (Sxxxx), the program is sent by the VDF but multiplied by 4. For this reason for example to set the speed to 10000 RPM I have to type in the MDI S2500.
cofhal
Re: MODBUSEZ Plugin
Postby SiemonB » Thu Jun 25, 2020 2:11 pm
Hi Dan,
Was hoping you could help me with the "Modbus Setup" Values.
I've gotten to the point where I succesfully can control my vfd with "Modbus Poll, but I've been trying for a while now but no luck.
Danfoss vlt 51manual https://files.danfoss.com/download/Drives/MG02K402.pdf
Thank you in advance!
SiemonB
Re: MODBUSEZ Plugin
Postby SiemonB » Thu Jun 25, 2020 3:24 pm
Looking for some help with my setup ( A Danfoss vlt51 Micro)
I've got it working over rs485 with "Modbus Poll", added some screengrabs from that.
When it comes to the plugin made by Dan I have some issues figuering out what goes where (manual added below)
VFD Manual:
SiemonB
