Units/steps setup
Units/steps setup
Postby Nickschneiders » Sat Jan 04, 2020 6:11 pm
I am in the process of setting up and tuning my CNC and I’ve run into a problem I don’t know how to solve.
I went through the axis setup and and used the calculator to figure out my units per step by measuring how far the bit moved and UCCNC calculated the units per step for me.
If I now jog the axis and compare the distance shown on the DRO to the actual movement everything matches. Once I load a g-code file created in Aspire, however, moving my DRO indicated position 10” only moves the cursor in the preview a couple of pixels. I did not realize the mismatch the first time and what should have been a z movement of 0.25” ran the bit straight into the waist board as far as it would go.
Essentially, the movement of my machine does not match up to the distance I expect from my tool path in Aspire.
Any ideas?
Nickschneiders
Re: Units/steps setup
Postby Robertspark » Sat Jan 04, 2020 6:29 pm
post your profile
post a sample of gcode
do you know what your XYZ axis steps per unit should be??
Postby Nickschneiders » Sat Jan 04, 2020 10:06 pm
I am running clearpath servos. I'll attach a screenshot of their setup but they are running at 6400 revolutions
thank you so much for your help
here is my profile
[Screensetsettings]
mainscreenfilename=Defaultscreenset
splashscreen=0
[axessettingscontrolX]
Axisenabled=True
Stepportnumber=1
Steppinnumber=15
Steppinnegate=False
Dirpinnumber=16
Dirportnumber=1
Dirpinnegate=True
Enapinnumber=17
Enaportnumber=1
Enapinnegate=False
Limitminuspinnumber=0
Limitminuspinnegate=False
Limitpluspinnumber=0
Limitpluspinnegate=False
Homepinnumber=0
Homepinnegate=False
Homedirectionpositive=False
Homeautozero=True
Homingvalue=0
Homingspeedup=10
Homingspeeddown=10
Stepsperunit=6137.67
Velocity=500
Acceleration=300
Softlimitpositive=0
Softlimitnegative=0
Backlashenable=False
Backlashdistance=0
Slaveaxis=None
Homeportnumber=0
Limitminusportnumber=0
Limitplusportnumber=0
Compaccel=360
Enabledelay=0
Currhilowpinnumber=0
Currhilowportnumber=0
Currhilowpinnegate=False
Homebackoff=0
[axessettingscontrolY]
Axisenabled=True
Stepportnumber=1
Steppinnumber=11
Steppinnegate=False
Dirpinnumber=12
Dirportnumber=1
Dirpinnegate=True
Enapinnumber=17
Enaportnumber=1
Enapinnegate=False
Limitminuspinnumber=5
Limitpluspinnumber=4
Homepinnumber=5
Homepinnegate=False
Homeautozero=True
Homingvalue=0
Homingspeedup=10
Homingspeeddown=10
Velocity=500
Acceleration=300
Softlimitpositive=0
Softlimitnegative=0
Backlashdistance=0
Slaveaxis=A
Homeportnumber=2
Limitminusportnumber=2
Limitplusportnumber=2
Compaccel=360
Enabledelay=0
Homebackoff=0
[axessettingscontrolZ]
Axisenabled=True
Stepportnumber=1
Steppinnumber=13
Steppinnegate=False
Dirpinnumber=14
Dirportnumber=1
Dirpinnegate=False
Enapinnumber=17
Enaportnumber=1
Enapinnegate=False
Limitminuspinnumber=2
Limitpluspinnumber=2
Homepinnumber=2
Homepinnegate=False
Homedirectionpositive=True
Homeautozero=True
Homingvalue=10
Homingspeedup=10
Homingspeeddown=10
Velocity=500
Acceleration=300
Softlimitpositive=0
Softlimitnegative=0
Backlashdistance=0
Slaveaxis=None
Homeportnumber=2
Compaccel=360
Enabledelay=0
Homebackoff=0
[axessettingscontrolA]
Axisenabled=True
Stepportnumber=1
Steppinnumber=9
Steppinnegate=False
Dirpinnumber=10
Dirportnumber=1
Dirpinnegate=True
Enapinnumber=17
Enaportnumber=1
Enapinnegate=False
Limitminuspinnumber=3
Homepinnumber=3
Homepinnegate=False
Homeautozero=True
Homingvalue=0
Homingspeedup=10
Homingspeeddown=10
Velocity=500
Acceleration=300
Softlimitpositive=0
Softlimitnegative=0
Backlashdistance=0
Homeportnumber=2
Compaccel=360
Enabledelay=0
Homebackoff=0
Dragknifeenabled=False
Dragknifestopatangle=0
Dragkniferetractatangle=0
Dragkniferetractheight=0
Dragknifemovebackfeedrate=0
Dragknifepulloutfeedrate=0
Rotaryaxis=False
Rotaryrollover=False
[axessettingscontrolB]
Axisenabled=False
Stepportnumber=0
Steppinnumber=0
Steppinnegate=False
Dirpinnumber=0
Dirportnumber=0
Dirpinnegate=False
Enapinnumber=0
Enaportnumber=0
Enapinnegate=False
Homepinnumber=0
Homepinnegate=False
Homeautozero=True
Homingvalue=0
Homingspeedup=500
Homingspeeddown=250
Stepsperunit=200
Velocity=2000
Acceleration=200
Softlimitpositive=0
Softlimitnegative=0
Backlashdistance=0
Homeportnumber=0
Compaccel=240
Enabledelay=0
Homebackoff=0
Rotaryaxis=False
[axessettingscontrolC]
Axisenabled=False
Steppinnumber=0
Stepportnumber=0
Steppinnegate=False
Dirpinnumber=0
Dirportnumber=0
Dirpinnegate=False
Enapinnumber=0
Enaportnumber=0
Enapinnegate=False
Homepinnumber=0
Homepinnegate=False
Homeautozero=True
Homingvalue=0
Homingspeedup=500
Homingspeeddown=250
Stepsperunit=200
Velocity=2000
Acceleration=200
Softlimitpositive=0
Softlimitnegative=0
Backlashdistance=0
Homeportnumber=0
Compaccel=240
Enabledelay=0
Homebackoff=0
Rotaryaxis=False
[Spindlesetupsettings]
IsSpindleinPWMMode=True
SpindlePWMoutpin=0
SpindlePWMoutpinnegate=False
SpindlePWMdirpin=0
SpindlePWMdirpinnegate=False
SpindlePWMfrequency=200
SpindlePWMminpercent=0
SpindlePWMmaxpercent=100
Spindlesteppin=0
Spindlesteppinnegate=False
Spindledirpin=0
Spindledirpinnegate=False
Spindlestepsperunit=500
Spindleacceleration=200
Spindleminvelocity=10
Spindlemaxvelocity=5000
Spindlerelaysenabled=True
M3relaypin=0
M3relaypinnegate=False
M4relaypin=0
M4relaypinnegate=False
M3ondelay=1000
M3offdelay=1000
M4ondelay=1000
M4offdelay=1000
Floodmistrelaysenabled=True
M7relaypin=0
M7relaypinnegate=False
M8relaypin=0
M8relaypinnegate=False
M7ondelay=1000
M8ondelay=1000
M9delay=0
SpindlePWMoutport=0
SpindlePWMdirport=0
Spindlestepport=0
Spindledirport=0
M3relayport=0
M4relayport=0
M7relayport=0
M8relayport=0
EncoderApin=0
EncoderAport=0
EncoderBpin=0
EncoderBport=0
Encoderreversedirection=False
EncoderPPR=400
Pulleyratio1=1
Pulleyminvel1=1
Pulleymaxvel1=1
Pulleyinuse=1
Pulleyratio2=1
Pulleyminvel2=1
Pulleymaxvel2=1
Pulleyratio3=1
Pulleyminvel3=1
Pulleymaxvel3=1
Pulleyratio4=1
Pulleyminvel4=1
Pulleymaxvel4=1
Pulleyratio5=1
Pulleyminvel5=1
Pulleymaxvel5=1
Pulleyratio6=1
Pulleyminvel6=1
Pulleymaxvel6=1
Pulleyratio7=1
Pulleyminvel7=1
Pulleymaxvel7=1
Pulleyratio8=1
Pulleyminvel8=1
Pulleymaxvel8=1
Pulleyratio9=1
Pulleyminvel9=1
Pulleymaxvel9=1
Pulleyratio10=1
Pulleyminvel10=1
Pulleymaxvel10=1
Pulleyratio11=1
Pulleyminvel11=1
Pulleymaxvel11=1
Pulleyratio12=1
Pulleyminvel12=1
Pulleymaxvel12=1
Pulleyratio13=1
Pulleyminvel13=1
Pulleymaxvel13=1
Pulleyratio14=1
Pulleyminvel14=1
Pulleymaxvel14=1
Pulleyratio15=1
Pulleyminvel15=1
Pulleymaxvel15=1
Usepulleys=False
[Generalsettings]
Constantvelocitymode=True
Stopatangle=89
Lookaheadlines=300
Softlimitsenable=False
Homesequence1=Z
Homesequence2=X
Homesequence3=Y
Homesequence4=None
Homesequence5=None
Homesequence6=None
Linearerror=0.03
Cornerserror=0.03
USBbuffersize=0.1
POSDROsdigits=4
Doontoolchange=0
MaxLinearaddlenght=1
MaxLinearunificationlenght=2
Kernelfreq=4
SafeZ=25
G73_backoff=0.4
Maximisescreenonstartup=True
Dwellinseconds=False
Runmodewhenunknowngcode=0
Softlimitsgcodeprecheck=False
Precompilemacrosonstartup=False
Arcradiustolerance=0.1
ResetG68onfileload=False
ResetG51onfileload=False
ResetG94onfileload=False
Debounce=0
DebounceTHC=0
DebounceHome=0
G41G42roundjoints=False
CheckHomeonCycleStart=False
ResetDereferenceHomes=False
[IOsetupsettings]
Estoppinnumber=0
Estoppinnegate=False
Probepinnumber=0
Probepinnegate=False
Chargepumppinnumber=0
Chargepumppinnegate=False
Chargepumplasermodeon=False
Chargepumpalwayson=False
CurrentHiLopinnumber=0
CurrentHiLopinnegate=False
Indexpinnumber=0
Indexprescaler=1
THCenable=False
THConpin=0
THConpinnegate=False
THCuppin=0
THCuppinnegate=False
THCdownpin=0
THCdownpinnegate=False
THCmin=0
THCmax=10
THCfeed=1000
THCalwayson=False
THCondelay=0
Estopportnumber=0
Chargepumpportnumber=0
CurrentHiLoportnumber=0
Indexportnumber=0
Probeportnumber=0
THConport=0
THCupport=0
THCdownport=0
MPG1pinA=0
MPG1pinB=0
MPG1portA=0
MPG1portB=0
MPG1prescaler=1
MPG1filter=10
MPG1speedmultiplier=10
FROchannel=0
SROchannel=0
JROchannel=0
FROminpercent=0
FROmaxpercent=0
SROminpercent=0
SROmaxpercent=0
JROminpercent=0
JROmaxpercent=0
SPPWMchannel=0
Ana1invarnum=0
Ana2invarnum=0
Ana1outvarnum=0
Ana2outvarnum=0
MPG1attachtoJRO=False
Laseroutputpinnumber=0
Laseroutputportnumber=0
Laseroutputpinnegate=False
THCantidiveenable=False
THCantidivepercent=0
Plasmapierceheight=0
Chargepump2pinnumber=0
Chargepump2portnumber=0
Chargepump2pinnegate=False
Digitialsyncoutputpinnumber1=0
Digitialsyncoutputportnumber1=0
Digitialsyncoutputpinnegate1=False
Digitialsyncoutputpinnumber2=0
Digitialsyncoutputportnumber2=0
Digitialsyncoutputpinnegate2=False
Digitialsyncoutputpinnumber3=0
Digitialsyncoutputportnumber3=0
Digitialsyncoutputpinnegate3=False
Digitialsyncoutputpinnumber4=0
Digitialsyncoutputportnumber4=0
Digitialsyncoutputpinnegate4=False
Digitialsyncoutputpinnumber5=0
Digitialsyncoutputportnumber5=0
Digitialsyncoutputpinnegate5=False
Digitialsyncoutputpinnumber6=0
Digitialsyncoutputportnumber6=0
Digitialsyncoutputpinnegate6=False
Digitialsyncoutputpinnumber7=0
Digitialsyncoutputportnumber7=0
Digitialsyncoutputpinnegate7=False
Digitialsyncoutputpinnumber8=0
Digitialsyncoutputportnumber8=0
Digitialsyncoutputpinnegate8=False
Digitialsyncoutputpinnumber9=0
Digitialsyncoutputportnumber9=0
Digitialsyncoutputpinnegate9=False
Digitialsyncoutputpinnumber10=0
Digitialsyncoutputportnumber10=0
Digitialsyncoutputpinnegate10=False
Probepin2number=0
Probeport2number=0
Probepin2negate=False
THCdelayenable=False
THCenableoutpin=0
THCenableoutport=0
THCenableoutpinnegate=False
THCantidiveoutpin=0
THCantidiveoutport=0
THCantidiveoutpinnegate=False
THCantidownoutpin=0
THCantidownoutport=0
THCantidownoutpinnegate=False
THCantidownenable=False
Ana3invarnum=0
Ana4invarnum=0
Ana3outvarnum=0
Ana4outvarnum=0
[Appearancesetupsettings]
2DTLCmarker=True
Viewerundonepathcolor=3381759
Viewerdonepathcolor=-5374161
Viewerrapidpathcolor=16711680
ViewerTCPmarkercolor=16776960
ViewerBackgroundcolor=0
Viewerboundariescolor=16777215
GVgcodecolors=16777215
GVmcodecolors=-233
GVscodecolors=-32513
GVfcodecolors=-21931
GVbackgroundcolor=-12698050
GVactualcodecolor=-16777216
GVactualcodemidlinescolor=-16777216
GVnotinterpretedcodecolor=16711680
GVaxiswordcolor=-8323328
GVcoordinatecolor=-9250052
TCPcone=True
TCPcross=False
RotateTCPwithplaneselection=True
Showzeromark=True
Zeromarkcolor=-16711681
DROwarningcolor=-65536
rotationpointmarkcolor=-65536
Showrotationmark=True
Showtoolpathboundaries=True
Highlightcolor=-1
radiusoffsetpathcolor=-13675
Showmessageonsoftlimits=True
ValidateTextfieldsonEnteronly=True
Disablejogpanelautopopup=False
ShowRcompanalysisonfileload=True
Disablevirtualmousemode=False
Disabletoolpathview=False
ShowtoolpathZzeroplate=False
ZplateXstart=0
ZplateYstart=0
ZplateXextents=100
ZplateYextents=100
ZplateZposition=0
ZplateZpositiononbottom=False
ZplatePlateOpacity=25
ZplateColor=-65536
ZplateXgrid=10
ZplateYgrid=10
ZplateGridOpacity=25
ZplateGridColor=-1
ZplateShowSoftlimits=False
ZplateSoftlimitsColor=-16711936
ZplateSoftlimitsOpacity=100
Savetooltableonclosing=False
Dontresettoolpathviewonreload=False
[Tooltablevalues]
TooloffsetZ0=0
TooloffsetZ1=0
TooloffsetZ2=0
TooloffsetZ3=0
TooloffsetZ4=0
TooloffsetZ5=0
TooloffsetZ6=0
TooloffsetZ7=0
TooloffsetZ8=0
TooloffsetZ9=0
TooloffsetZ10=0
TooloffsetZ11=0
TooloffsetZ12=0
TooloffsetZ13=0
TooloffsetZ14=0
TooloffsetZ15=0
TooloffsetZ16=0
TooloffsetZ17=0
TooloffsetZ18=0
TooloffsetZ19=0
TooloffsetZ20=0
TooloffsetZ21=0
TooloffsetZ22=0
TooloffsetZ23=0
TooloffsetZ24=0
TooloffsetZ25=0
TooloffsetZ26=0
TooloffsetZ27=0
TooloffsetZ28=0
TooloffsetZ29=0
TooloffsetZ30=0
TooloffsetZ31=0
TooloffsetZ32=0
TooloffsetZ33=0
TooloffsetZ34=0
TooloffsetZ35=0
TooloffsetZ36=0
TooloffsetZ37=0
TooloffsetZ38=0
TooloffsetZ39=0
TooloffsetZ40=0
TooloffsetZ41=0
TooloffsetZ42=0
TooloffsetZ43=0
TooloffsetZ44=0
TooloffsetZ45=0
TooloffsetZ46=0
TooloffsetZ47=0
TooloffsetZ48=0
TooloffsetZ49=0
TooloffsetZ50=0
TooloffsetZ51=0
TooloffsetZ52=0
TooloffsetZ53=0
TooloffsetZ54=0
TooloffsetZ55=0
TooloffsetZ56=0
TooloffsetZ57=0
TooloffsetZ58=0
TooloffsetZ59=0
TooloffsetZ60=0
TooloffsetZ61=0
TooloffsetZ62=0
TooloffsetZ63=0
TooloffsetZ64=0
TooloffsetZ65=0
TooloffsetZ66=0
TooloffsetZ67=0
TooloffsetZ68=0
TooloffsetZ69=0
TooloffsetZ70=0
TooloffsetZ71=0
TooloffsetZ72=0
TooloffsetZ73=0
TooloffsetZ74=0
TooloffsetZ75=0
TooloffsetZ76=0
TooloffsetZ77=0
TooloffsetZ78=0
TooloffsetZ79=0
TooloffsetZ80=0
TooloffsetZ81=0
TooloffsetZ82=0
TooloffsetZ83=0
TooloffsetZ84=0
TooloffsetZ85=0
TooloffsetZ86=0
TooloffsetZ87=0
TooloffsetZ88=0
TooloffsetZ89=0
TooloffsetZ90=0
TooloffsetZ91=0
TooloffsetZ92=0
TooloffsetZ93=0
TooloffsetZ94=0
TooloffsetZ95=0
TooloffsetZ96=0
ToolDia0=0
ToolDia1=0
ToolDia2=0
ToolDia3=0
ToolDia4=0
ToolDia5=0
ToolDia6=0
ToolDia7=0
ToolDia8=0
ToolDia9=0
ToolDia10=0
ToolDia11=0
ToolDia12=0
ToolDia13=0
ToolDia14=0
ToolDia15=0
ToolDia16=0
ToolDia17=0
ToolDia18=0
ToolDia19=0
ToolDia20=0
ToolDia21=0
ToolDia22=0
ToolDia23=0
ToolDia24=0
ToolDia25=0
ToolDia26=0
ToolDia27=0
ToolDia28=0
ToolDia29=0
ToolDia30=0
ToolDia31=0
ToolDia32=0
ToolDia33=0
ToolDia34=0
ToolDia35=0
ToolDia36=0
ToolDia37=0
ToolDia38=0
ToolDia39=0
ToolDia40=0
ToolDia41=0
ToolDia42=0
ToolDia43=0
ToolDia44=0
ToolDia45=0
ToolDia46=0
ToolDia47=0
ToolDia48=0
ToolDia49=0
ToolDia50=0
ToolDia51=0
ToolDia52=0
ToolDia53=0
ToolDia54=0
ToolDia55=0
ToolDia56=0
ToolDia57=0
ToolDia58=0
ToolDia59=0
ToolDia60=0
ToolDia61=0
ToolDia62=0
ToolDia63=0
ToolDia64=0
ToolDia65=0
ToolDia66=0
ToolDia67=0
ToolDia68=0
ToolDia69=0
ToolDia70=0
ToolDia71=0
ToolDia72=0
ToolDia73=0
ToolDia74=0
ToolDia75=0
ToolDia76=0
ToolDia77=0
ToolDia78=0
ToolDia79=0
ToolDia80=0
ToolDia81=0
ToolDia82=0
ToolDia83=0
ToolDia84=0
ToolDia85=0
ToolDia86=0
ToolDia87=0
ToolDia88=0
ToolDia89=0
ToolDia90=0
ToolDia91=0
ToolDia92=0
ToolDia93=0
ToolDia94=0
ToolDia95=0
ToolDia96=0
[Workoffset_G54]
WorkoffsetX=137.01
WorkoffsetY=-184.335
WorkoffsetZ=-522.8
WorkoffsetA=0
WorkoffsetB=0
WorkoffsetC=0
[Workoffset_G55]
WorkoffsetX=0
WorkoffsetY=0
WorkoffsetZ=0
WorkoffsetA=0
WorkoffsetB=0
WorkoffsetC=0
[Workoffset_G56]
WorkoffsetX=0
WorkoffsetY=0
WorkoffsetZ=0
WorkoffsetA=0
WorkoffsetB=0
WorkoffsetC=0
[Workoffset_G57]
WorkoffsetX=0
WorkoffsetY=0
WorkoffsetZ=0
WorkoffsetA=0
WorkoffsetB=0
WorkoffsetC=0
[Workoffset_G58]
WorkoffsetX=0
WorkoffsetY=0
WorkoffsetZ=0
WorkoffsetA=0
WorkoffsetB=0
WorkoffsetC=0
[Workoffset_G59]
WorkoffsetX=0
WorkoffsetY=0
WorkoffsetZ=0
WorkoffsetA=0
WorkoffsetB=0
WorkoffsetC=0
[Machinecoords]
MachinecoordsX=307.421949
MachinecoordsY=26.542548
MachinecoordsZ=-498.561263
MachinecoordsA=0
MachinecoordsB=0
MachinecoordsC=0
[Tooloffsetcoords]
TooloffsetZ=0
[Systemmessages]
Message0=Valid license key was not found! Application will run in demo mode!
Message1=Firmware update done!
Message2=No UC100 connection was found! Application will run in demo mode!
Message3=Firmware update in progress! Please wait and do not close the application...
Message4=The application lost the connection with the motion controller device. [nl] Check the connection. The application is closing now! [nl] Save offsets?
Message5=A machine axis position software limit was reached. The axis was now stopped.
Message6=The reset logic of the software is active! [nl] Remove the reset condition with pressing the blinking reset button on the screen. [nl] If the reset condition cannot be removed can be due to an external e-stop button is pressed in or a limit switch on the machine tool is active. [nl] Please check the Diagnostics page for the input signals condition.
Message7=The current job workspace is out of the set software limits.[nl] Adjust the softlimits to fit the job extents or disable the softlimits.
Message8=The axis is disabled. To calibrate this axis enable the axis first.
Message9=An internal error occured. The application is closing now.
Message10=Enter a valid distance in absolute value!
Message11=The calculated steps per value was saved.
Message12=Please enter valid data.
Message13=Active fixture:
Message14=Are you sure you want to close?
Message15=
Message16=
Message17=
Message18=
Message19=
Message20=
Message21=
Message22=
Message23=
Message24=
Message25=
Message26=
Message27=The Default profile cannot be deleted!
Message28=File error.Could not delete the profile's macro library!
Message29=Do you really want to delete the profile :
Message30=File error.Could not copy default macros to profile!
Message31=was loaded!
Message32=The axis calibration makes a measurement to calibrate the steps per units resolution value for the machine axis. To abort and close this window press the cancel button.
Message33=Mark the current position of the machine axis. Set the distance and the feedrate on this page and press the OK button to make a movement.
Message34=Measure the travel distance on the machine axis from the previously marked point to the current point. Type the measured value to the field below and press OK.
Message35=The new steps per value was calculated and written to the below field. To save the new value press OK. The process is then finished.
Message36=Switch spindle on first
Message37=Move Z-axis first to safeZ height:
Message38=Make movement with safeZ to:
Message39=Start position(Units):
Message40=Actual steps per Unit:
Message41=Distance to move(Units):
Message42=Feed rate(Units/min):
Message43=Distance measured(Units):
Message44=Steps per Units calculated value:
Message45=The software limits is lower than the safeZ height. Execute the command anyways?
Message46=was created!
[Hotkeysettings]
Keycode1=39
Buttoncode1=147
Keycode2=37
Buttoncode2=148
Keycode3=38
Buttoncode3=149
Keycode4=40
Buttoncode4=150
Keycode5=33
Buttoncode5=151
Keycode6=34
Buttoncode6=152
Keycode7=45
Buttoncode7=153
Keycode8=46
Buttoncode8=154
Keycode9=81
Buttoncode9=155
Keycode10=65
Buttoncode10=156
Keycode11=87
Buttoncode11=157
Keycode12=83
Buttoncode12=158
Keycode13=27
Buttoncode13=130
Keycode14=0
Buttoncode14=0
Keycode15=0
Buttoncode15=0
Keycode16=0
Buttoncode16=0
Keycode17=0
Buttoncode17=0
Keycode18=0
Buttoncode18=0
Keycode19=0
Buttoncode19=0
Keycode20=0
Buttoncode20=0
Keycode21=0
Buttoncode21=0
Keycode22=0
Buttoncode22=0
Keycode23=0
Buttoncode23=0
Keycode24=0
Buttoncode24=0
Keycode25=0
Buttoncode25=0
Keycode26=0
Buttoncode26=0
Keycode27=0
Buttoncode27=0
Keycode28=0
Buttoncode28=0
Keycode29=0
Buttoncode29=0
Keycode30=0
Buttoncode30=0
Keycode31=0
Buttoncode31=0
Keycode32=0
Buttoncode32=0
Keycode33=0
Buttoncode33=0
Keycode34=0
Buttoncode34=0
Keycode35=0
Buttoncode35=0
Keycode36=0
Buttoncode36=0
Keycode37=0
Buttoncode37=0
Keycode38=0
Buttoncode38=0
Keycode39=0
Buttoncode39=0
Keycode40=0
Buttoncode40=0
Keycode41=0
Buttoncode41=0
Keycode42=0
Buttoncode42=0
Keycode43=0
Buttoncode43=0
Keycode44=0
Buttoncode44=0
Keycode45=0
Buttoncode45=0
Keycode46=0
Buttoncode46=0
Keycode47=0
Buttoncode47=0
Keycode48=0
Buttoncode48=0
Keycode49=0
Buttoncode49=0
Keycode50=0
Buttoncode50=0
Keycode51=0
Buttoncode51=0
Keycode52=0
Buttoncode52=0
Keycode53=0
Buttoncode53=0
Keycode54=0
Buttoncode54=0
Keycode55=0
Buttoncode55=0
Keycode56=0
Buttoncode56=0
Keycode57=0
Buttoncode57=0
Keycode58=0
Buttoncode58=0
Keycode59=0
Buttoncode59=0
Keycode60=0
Buttoncode60=0
Keycode61=0
Buttoncode61=0
Keycode62=0
Buttoncode62=0
Keycode63=0
Buttoncode63=0
Keycode64=0
Buttoncode64=0
Keycode65=0
Buttoncode65=0
Keycode66=0
Buttoncode66=0
Keycode67=0
Buttoncode67=0
Keycode68=0
Buttoncode68=0
Keycode69=0
Buttoncode69=0
Keycode70=0
Buttoncode70=0
Keycode71=0
Buttoncode71=0
Keycode72=0
Buttoncode72=0
Keycode73=0
Buttoncode73=0
Keycode74=0
Buttoncode74=0
Keycode75=0
Buttoncode75=0
Keycode76=0
Buttoncode76=0
Keycode77=0
Buttoncode77=0
Keycode78=0
Buttoncode78=0
Keycode79=0
Buttoncode79=0
Keycode80=0
Buttoncode80=0
Keycode81=0
Buttoncode81=0
Keycode82=0
Buttoncode82=0
Keycode83=0
Buttoncode83=0
Keycode84=0
Buttoncode84=0
Keycode85=0
Buttoncode85=0
Keycode86=0
Buttoncode86=0
Keycode87=0
Buttoncode87=0
Keycode88=0
Buttoncode88=0
Keycode89=0
Buttoncode89=0
Keycode90=0
Buttoncode90=0
Keycode91=0
Buttoncode91=0
Keycode92=0
Buttoncode92=0
Keycode93=0
Buttoncode93=0
Keycode94=0
Buttoncode94=0
Keycode95=0
Buttoncode95=0
Keycode96=0
Buttoncode96=0
[Inputtriggersettings]
Pin1=0
Port1=0
Buttoncode1=0
Activelow1=False
Pin2=0
Port2=0
Buttoncode2=0
Activelow2=False
Pin3=0
Port3=0
Buttoncode3=0
Activelow3=False
Pin4=0
Port4=0
Buttoncode4=0
Activelow4=False
Pin5=0
Port5=0
Buttoncode5=0
Activelow5=False
Pin6=0
Port6=0
Buttoncode6=0
Activelow6=False
Pin7=0
Port7=0
Buttoncode7=0
Activelow7=False
Pin8=0
Port8=0
Buttoncode8=0
Activelow8=False
Pin9=0
Port9=0
Buttoncode9=0
Activelow9=False
Pin10=0
Port10=0
Buttoncode10=0
Activelow10=False
Pin11=0
Port11=0
Buttoncode11=0
Activelow11=False
Pin12=0
Port12=0
Buttoncode12=0
Activelow12=False
Pin13=0
Port13=0
Buttoncode13=0
Activelow13=False
Pin14=0
Port14=0
Buttoncode14=0
Activelow14=False
Pin15=0
Port15=0
Buttoncode15=0
Activelow15=False
Pin16=0
Port16=0
Buttoncode16=0
Activelow16=False
Pin17=0
Port17=0
Buttoncode17=0
Activelow17=False
Pin18=0
Port18=0
Buttoncode18=0
Activelow18=False
Pin19=0
Port19=0
Buttoncode19=0
Activelow19=False
Pin20=0
Port20=0
Buttoncode20=0
Activelow20=False
Pin21=0
Port21=0
Buttoncode21=0
Activelow21=False
Pin22=0
Port22=0
Buttoncode22=0
Activelow22=False
Pin23=0
Port23=0
Buttoncode23=0
Activelow23=False
Pin24=0
Port24=0
Buttoncode24=0
Activelow24=False
Pin25=0
Port25=0
Buttoncode25=0
Activelow25=False
Pin26=0
Port26=0
Buttoncode26=0
Activelow26=False
Pin27=0
Port27=0
Buttoncode27=0
Activelow27=False
Pin28=0
Port28=0
Buttoncode28=0
Activelow28=False
Pin29=0
Port29=0
Buttoncode29=0
Activelow29=False
Pin30=0
Port30=0
Buttoncode30=0
Activelow30=False
Pin31=0
Port31=0
Buttoncode31=0
Activelow31=False
Pin32=0
Port32=0
Buttoncode32=0
Activelow32=False
Pin33=0
Port33=0
Buttoncode33=0
Activelow33=False
Pin34=0
Port34=0
Buttoncode34=0
Activelow34=False
Pin35=0
Port35=0
Buttoncode35=0
Activelow35=False
Pin36=0
Port36=0
Buttoncode36=0
Activelow36=False
Pin37=0
Port37=0
Buttoncode37=0
Activelow37=False
Pin38=0
Port38=0
Buttoncode38=0
Activelow38=False
Pin39=0
Port39=0
Buttoncode39=0
Activelow39=False
Pin40=0
Port40=0
Buttoncode40=0
Activelow40=False
Pin41=0
Port41=0
Buttoncode41=0
Activelow41=False
Pin42=0
Port42=0
Buttoncode42=0
Activelow42=False
Pin43=0
Port43=0
Buttoncode43=0
Activelow43=False
Pin44=0
Port44=0
Buttoncode44=0
Activelow44=False
Pin45=0
Port45=0
Buttoncode45=0
Activelow45=False
Pin46=0
Port46=0
Buttoncode46=0
Activelow46=False
Pin47=0
Port47=0
Buttoncode47=0
Activelow47=False
Pin48=0
Port48=0
Buttoncode48=0
Activelow48=False
Pin49=0
Port49=0
Buttoncode49=0
Activelow49=False
Pin50=0
Port50=0
Buttoncode50=0
Activelow50=False
Pin51=0
Port51=0
Buttoncode51=0
Activelow51=False
Pin52=0
Port52=0
Buttoncode52=0
Activelow52=False
Pin53=0
Port53=0
Buttoncode53=0
Activelow53=False
Pin54=0
Port54=0
Buttoncode54=0
Activelow54=False
Pin55=0
Port55=0
Buttoncode55=0
Activelow55=False
Pin56=0
Port56=0
Buttoncode56=0
Activelow56=False
Pin57=0
Port57=0
Buttoncode57=0
Activelow57=False
Pin58=0
Port58=0
Buttoncode58=0
Activelow58=False
Pin59=0
Port59=0
Buttoncode59=0
Activelow59=False
Pin60=0
Port60=0
Buttoncode60=0
Activelow60=False
Pin61=0
Port61=0
Buttoncode61=0
Activelow61=False
Pin62=0
Port62=0
Buttoncode62=0
Activelow62=False
Pin63=0
Port63=0
Buttoncode63=0
Activelow63=False
Pin64=0
Port64=0
Buttoncode64=0
Activelow64=False
Pin65=0
Port65=0
Buttoncode65=0
Activelow65=False
Pin66=0
Port66=0
Buttoncode66=0
Activelow66=False
Pin67=0
Port67=0
Buttoncode67=0
Activelow67=False
Pin68=0
Port68=0
Buttoncode68=0
Activelow68=False
Pin69=0
Port69=0
Buttoncode69=0
Activelow69=False
Pin70=0
Port70=0
Buttoncode70=0
Activelow70=False
Pin71=0
Port71=0
Buttoncode71=0
Activelow71=False
Pin72=0
Port72=0
Buttoncode72=0
Activelow72=False
Pin73=0
Port73=0
Buttoncode73=0
Activelow73=False
Pin74=0
Port74=0
Buttoncode74=0
Activelow74=False
Pin75=0
Port75=0
Buttoncode75=0
Activelow75=False
Pin76=0
Port76=0
Buttoncode76=0
Activelow76=False
Pin77=0
Port77=0
Buttoncode77=0
Activelow77=False
Pin78=0
Port78=0
Buttoncode78=0
Activelow78=False
Pin79=0
Port79=0
Buttoncode79=0
Activelow79=False
Pin80=0
Port80=0
Buttoncode80=0
Activelow80=False
Pin81=0
Port81=0
Buttoncode81=0
Activelow81=False
Pin82=0
Port82=0
Buttoncode82=0
Activelow82=False
Pin83=0
Port83=0
Buttoncode83=0
Activelow83=False
Pin84=0
Port84=0
Buttoncode84=0
Activelow84=False
Pin85=0
Port85=0
Buttoncode85=0
Activelow85=False
Pin86=0
Port86=0
Buttoncode86=0
Activelow86=False
Pin87=0
Port87=0
Buttoncode87=0
Activelow87=False
Pin88=0
Port88=0
Buttoncode88=0
Activelow88=False
Pin89=0
Port89=0
Buttoncode89=0
Activelow89=False
Pin90=0
Port90=0
Buttoncode90=0
Activelow90=False
Pin91=0
Port91=0
Buttoncode91=0
Activelow91=False
Pin92=0
Port92=0
Buttoncode92=0
Activelow92=False
Pin93=0
Port93=0
Buttoncode93=0
Activelow93=False
Pin94=0
Port94=0
Buttoncode94=0
Activelow94=False
Pin95=0
Port95=0
Buttoncode95=0
Activelow95=False
Pin96=0
Port96=0
Buttoncode96=0
Activelow96=False
[Outputtriggersettings]
Pin1=0
Port1=0
LEDcode1=0
Invert1=False
Pin2=0
Port2=0
LEDcode2=0
Invert2=False
Pin3=0
Port3=0
LEDcode3=0
Invert3=False
Pin4=0
Port4=0
LEDcode4=0
Invert4=False
Pin5=0
Port5=0
LEDcode5=0
Invert5=False
Pin6=0
Port6=0
LEDcode6=0
Invert6=False
Pin7=0
Port7=0
LEDcode7=0
Invert7=False
Pin8=0
Port8=0
LEDcode8=0
Invert8=False
Pin9=0
Port9=0
LEDcode9=0
Invert9=False
Pin10=0
Port10=0
LEDcode10=0
Invert10=False
Pin11=0
Port11=0
LEDcode11=0
Invert11=False
Pin12=0
Port12=0
LEDcode12=0
Invert12=False
Pin13=0
Port13=0
LEDcode13=0
Invert13=False
Pin14=0
Port14=0
LEDcode14=0
Invert14=False
Pin15=0
Port15=0
LEDcode15=0
Invert15=False
Pin16=0
Port16=0
LEDcode16=0
Invert16=False
Pin17=0
Port17=0
LEDcode17=0
Invert17=False
Pin18=0
Port18=0
LEDcode18=0
Invert18=False
Pin19=0
Port19=0
LEDcode19=0
Invert19=False
Pin20=0
Port20=0
LEDcode20=0
Invert20=False
Pin21=0
Port21=0
LEDcode21=0
Invert21=False
Pin22=0
Port22=0
LEDcode22=0
Invert22=False
Pin23=0
Port23=0
LEDcode23=0
Invert23=False
Pin24=0
Port24=0
LEDcode24=0
Invert24=False
Pin25=0
Port25=0
LEDcode25=0
Invert25=False
Pin26=0
Port26=0
LEDcode26=0
Invert26=False
Pin27=0
Port27=0
LEDcode27=0
Invert27=False
Pin28=0
Port28=0
LEDcode28=0
Invert28=False
Pin29=0
Port29=0
LEDcode29=0
Invert29=False
Pin30=0
Port30=0
LEDcode30=0
Invert30=False
Pin31=0
Port31=0
LEDcode31=0
Invert31=False
Pin32=0
Port32=0
LEDcode32=0
Invert32=False
Pin33=0
Port33=0
LEDcode33=0
Invert33=False
Pin34=0
Port34=0
LEDcode34=0
Invert34=False
Pin35=0
Port35=0
LEDcode35=0
Invert35=False
Pin36=0
Port36=0
LEDcode36=0
Invert36=False
Pin37=0
Port37=0
LEDcode37=0
Invert37=False
Pin38=0
Port38=0
LEDcode38=0
Invert38=False
Pin39=0
Port39=0
LEDcode39=0
Invert39=False
Pin40=0
Port40=0
LEDcode40=0
Invert40=False
Pin41=0
Port41=0
LEDcode41=0
Invert41=False
Pin42=0
Port42=0
LEDcode42=0
Invert42=False
Pin43=0
Port43=0
LEDcode43=0
Invert43=False
Pin44=0
Port44=0
LEDcode44=0
Invert44=False
Pin45=0
Port45=0
LEDcode45=0
Invert45=False
Pin46=0
Port46=0
LEDcode46=0
Invert46=False
Pin47=0
Port47=0
LEDcode47=0
Invert47=False
Pin48=0
Port48=0
LEDcode48=0
Invert48=False
Pin49=0
Port49=0
LEDcode49=0
Invert49=False
Pin50=0
Port50=0
LEDcode50=0
Invert50=False
Pin51=0
Port51=0
LEDcode51=0
Invert51=False
Pin52=0
Port52=0
LEDcode52=0
Invert52=False
Pin53=0
Port53=0
LEDcode53=0
Invert53=False
Pin54=0
Port54=0
LEDcode54=0
Invert54=False
Pin55=0
Port55=0
LEDcode55=0
Invert55=False
Pin56=0
Port56=0
LEDcode56=0
Invert56=False
Pin57=0
Port57=0
LEDcode57=0
Invert57=False
Pin58=0
Port58=0
LEDcode58=0
Invert58=False
Pin59=0
Port59=0
LEDcode59=0
Invert59=False
Pin60=0
Port60=0
LEDcode60=0
Invert60=False
Pin61=0
Port61=0
LEDcode61=0
Invert61=False
Pin62=0
Port62=0
LEDcode62=0
Invert62=False
Pin63=0
Port63=0
LEDcode63=0
Invert63=False
Pin64=0
Port64=0
LEDcode64=0
Invert64=False
Pin65=0
Port65=0
LEDcode65=0
Invert65=False
Pin66=0
Port66=0
LEDcode66=0
Invert66=False
Pin67=0
Port67=0
LEDcode67=0
Invert67=False
Pin68=0
Port68=0
LEDcode68=0
Invert68=False
Pin69=0
Port69=0
LEDcode69=0
Invert69=False
Pin70=0
Port70=0
LEDcode70=0
Invert70=False
Pin71=0
Port71=0
LEDcode71=0
Invert71=False
Pin72=0
Port72=0
LEDcode72=0
Invert72=False
Pin73=0
Port73=0
LEDcode73=0
Invert73=False
Pin74=0
Port74=0
LEDcode74=0
Invert74=False
Pin75=0
Port75=0
LEDcode75=0
Invert75=False
Pin76=0
Port76=0
LEDcode76=0
Invert76=False
Pin77=0
Port77=0
LEDcode77=0
Invert77=False
Pin78=0
Port78=0
LEDcode78=0
Invert78=False
Pin79=0
Port79=0
LEDcode79=0
Invert79=False
Pin80=0
Port80=0
LEDcode80=0
Invert80=False
Pin81=0
Port81=0
LEDcode81=0
Invert81=False
Pin82=0
Port82=0
LEDcode82=0
Invert82=False
Pin83=0
Port83=0
LEDcode83=0
Invert83=False
Pin84=0
Port84=0
LEDcode84=0
Invert84=False
Pin85=0
Port85=0
LEDcode85=0
Invert85=False
Pin86=0
Port86=0
LEDcode86=0
Invert86=False
Pin87=0
Port87=0
LEDcode87=0
Invert87=False
Pin88=0
Port88=0
LEDcode88=0
Invert88=False
Pin89=0
Port89=0
LEDcode89=0
Invert89=False
Pin90=0
Port90=0
LEDcode90=0
Invert90=False
Pin91=0
Port91=0
LEDcode91=0
Invert91=False
Pin92=0
Port92=0
LEDcode92=0
Invert92=False
Pin93=0
Port93=0
LEDcode93=0
Invert93=False
Pin94=0
Port94=0
LEDcode94=0
Invert94=False
Pin95=0
Port95=0
LEDcode95=0
Invert95=False
Pin96=0
Port96=0
LEDcode96=0
Invert96=False
[CAMsettings]
Tooldia=6
Startdepth=0
Cutdepth=-1
Cutperpass=1
SafeZ=25
Feedrate=1000
Tooloverlap=50
Plungerate=400
Spindlespeed=5000
Arctolerance=0.01
[Laserengraveplugin]
workpiecewidth=50
workpieceheight=50
keepaspectratio=True
Yscandistance=0.2
Feedrate=1000
Originsetting=7
[Plugins_enabled]
Debugger.dll=False
Diagnostics.dll=False
Laserengrave.dll=False
Plugintest.dll=False
Webcamera.dll=False
Printer3D.dll=False
UCR200Plugin.dll=False
Xbox360controller.dll=False
Scope.dll=False
Probing.dll=True
[Plugins_callstartup]
Debugger.dll=False
Webcamera.dll=False
Printer3D.dll=False
Scope.dll=False
Probing.dll=True
[Macroloops]
Macroloopautorun0=False
Macroloopnumber0=0
Macroloopautorun1=False
Macroloopnumber1=0
Macroloopautorun2=False
Macroloopnumber2=0
Macroloopautorun3=False
Macroloopnumber3=0
Macroloopautorun4=False
Macroloopnumber4=0
Macroloopautorun5=False
Macroloopnumber5=0
Macroloopautorun6=False
Macroloopnumber6=0
Macroloopautorun7=False
Macroloopnumber7=0
Macroloopautorun8=False
Macroloopnumber8=0
Macroloopautorun9=False
Macroloopnumber9=0
Macroloopautorun10=False
Macroloopnumber10=0
Macroloopautorun11=False
Macroloopnumber11=0
Macroloopautorun12=False
Macroloopnumber12=0
Macroloopautorun13=False
Macroloopnumber13=0
Macroloopautorun14=False
Macroloopnumber14=0
Macroloopautorun15=False
Macroloopnumber15=0
Macroloopautorun16=False
Macroloopnumber16=0
Macroloopautorun17=False
Macroloopnumber17=0
Macroloopautorun18=False
Macroloopnumber18=0
Macroloopautorun19=False
Macroloopnumber19=0
Macroloopautorun20=False
Macroloopnumber20=0
Macroloopautorun21=False
Macroloopnumber21=0
Macroloopautorun22=False
Macroloopnumber22=0
Macroloopautorun23=False
Macroloopnumber23=0
Macroloopautorun24=False
Macroloopnumber24=0
Macroloopautorun25=False
Macroloopnumber25=0
Macroloopautorun26=False
Macroloopnumber26=0
Macroloopautorun27=False
Macroloopnumber27=0
Macroloopautorun28=False
Macroloopnumber28=0
Macroloopautorun29=False
Macroloopnumber29=0
Macroloopautorun30=False
Macroloopnumber30=0
Macroloopautorun31=False
Macroloopnumber31=0
Macroloopautorun32=False
Macroloopnumber32=0
Macroloopautorun33=False
Macroloopnumber33=0
Macroloopautorun34=False
Macroloopnumber34=0
Macroloopautorun35=False
Macroloopnumber35=0
Macroloopautorun36=False
Macroloopnumber36=0
Macroloopautorun37=False
Macroloopnumber37=0
Macroloopautorun38=False
Macroloopnumber38=0
Macroloopautorun39=False
Macroloopnumber39=0
Macroloopautorun40=False
Macroloopnumber40=0
Macroloopautorun41=False
Macroloopnumber41=0
Macroloopautorun42=False
Macroloopnumber42=0
Macroloopautorun43=False
Macroloopnumber43=0
Macroloopautorun44=False
Macroloopnumber44=0
Macroloopautorun45=False
Macroloopnumber45=0
Macroloopautorun46=False
Macroloopnumber46=0
Macroloopautorun47=False
Macroloopnumber47=0
[Probing]
Mode=1
Tool=1,Z,0
Simple=X,0
Angle=X,0,X,0
Pocket=X,0
Outer=X,0,X,0
InnerCorner=1,X,0,X,0
OuterCorner=1,X,0,X,0
RectInner=X,0,X,0
CircleInner=X,0,X,0
RectOuter=X,0,X,0,X,0
CircleOuter=X,0,X,0,X,0
Common=X,0,X,0,X,0
GageHeight=0
FineDistance=0.0001
Retract=0
FastFeed=0.001
FineFeed=0.001
ZeroProbedAxis=False
ZeroOnAllOffsets=False
SingleProbeMode=False
EnableRetract=False
PauseBeforeProbe=False
CommonAxisSettings=False
Axis1CountGage=False
Axis1CountDia=False
Axis2CountGage=False
Axis2CountDia=False
SafeX=0
SafeY=0
SafeZ=0
SafeXPositive=False
SafeYPositive=False
SafeZPositive=False
SaveMobileProbePos=False
SaveWpReferences=False
OverrideProbeDia=False
ProbeDiameterOvr=0
ReferenceToolNumber=0
FixedProbePos=False,-1,True,0,True,0,True,0,True,0,False,0,False,0,0,False,0
[Statistics]
TotalM3s=23
TotalM4s=0
TotalM7s=0
TotalM8s=1
Totaltimedays=0
Totaltimehours=2
Totaltimeminutes=48
Totaltimeseconds=36
M3timedays=0
M3timehours=0
M3timeminutes=21
M3timeseconds=17
M4timedays=0
M4timehours=0
M4timeminutes=0
M4timeseconds=0
Cyclestimedays=0
Cyclestimehours=0
Cyclestimeminutes=25
Cyclestimeseconds=30
TotaldistX=39900
TotalcutX=16543
TotaldistY=211008
TotalcutY=178809
TotaldistZ=5771
TotalcutZ=3733
TotaldistA=25636
TotalcutA=6830
TotaldistB=0
TotalcutB=0
TotaldistC=0
TotalcutC=0
UCdevicetype=AXBB
Softwareversion=1.2111
[SpindlePIDsettings]
PIDenable=False
Kp=1
Kd=0
Ki=0.01
Samplingtime=10
[AUXencodersettings]
AUXencoder1pinA=0
AUXencoder1portA=0
AUXencoder1pinB=0
AUXencoder1portB=0
AUXencoder2pinA=0
AUXencoder2portA=0
AUXencoder2pinB=0
AUXencoder2portB=0
AUXencoder3pinA=0
AUXencoder3portA=0
AUXencoder3pinB=0
AUXencoder3portB=0
AUXencoder4pinA=0
AUXencoder4portA=0
AUXencoder4pinB=0
AUXencoder4portB=0
AUXencoder5pinA=0
AUXencoder5portA=0
AUXencoder5pinB=0
AUXencoder5portB=0
AUXencoder6pinA=0
AUXencoder6portA=0
AUXencoder6pinB=0
AUXencoder6portB=0
Aux1Encodercountsper=1
Aux2Encodercountsper=1
Aux3Encodercountsper=1
Aux4Encodercountsper=1
Aux5Encodercountsper=1
Aux6Encodercountsper=1
[Digitizesettings]
Addaxisnames=False
Xinclude=True
Yinclude=True
Zinclude=True
Ainclude=False
Binclude=False
Cinclude=False
Commaseparation=False
Filenametosave=C:\UCCNC\Example_codes\Digitize.txt
Numberofdigits=4
Probedia=0
Clearfilenamewhenfinished=False
[RFHsettings]
Switchspindlemode=1
Doinitialmoveswithrapid=False
gcode
( Gantry Square Test Drill )
( File created: Saturday January 04 2020 - 12:03 PM)
( for UCCNC from Vectric )
( Material Size)
( X= 609.600, Y= 609.600, Z= 19.050)
(Toolpaths used in this file:)
(Gantry Square Test Drill)
(Tools used in this file: )
(1 = End Mill {0.25 inch})
N100G00G21G17G90G40G49G80
N110G71G91.1
N120T1M06
N130 (End Mill {0.25 inch})
N140G00G43Z20.320H1
N150S18000M03
N160(Toolpath:- Gantry Square Test Drill)
N170()
N180G94
N190X0.000Y0.000F3810.0
N200G00X113.970Y113.970Z5.080
N210G1Z-6.350F2032.0
N220G00Z5.080
N230G00Y495.630
N240G1Z-6.350F2032.0
N250G00Z5.080
N260G00X495.630
N270G1Z-6.350F2032.0
N280G00Z5.080
N290G00Y113.970
N300G1Z-6.350F2032.0
N310G00Z5.080
N320G00Z20.320
N330G00X0.000Y0.000
N340M09
N350M30
Nickschneiders
Postby Robertspark » Sun Jan 05, 2020 12:00 pm
You probably want to start by checking out the input and output pins and ports are wired correctly
Next you probable want to consider your axis steps per unit.
The X, Y, Z and A axis , all are listed as 6137.67 steps per unit (inch?)
I am not sure how you are driving these axis (ball screws, rack, pinion, threaded rod, belt.... etc).
But, your clearpath steppers require 6400 steps per revolution, and if 6137.67 steps = 1 inch of movement, that would mean that 1 revolution of motor movement equals ~1.0427 inch of machine movement.... (~26.49mm)
I always recommend that you try to understand your machine and work out it's motion as best as you can ...
say you have a ball screw, with a 5mm pitch (~0.198" pitch or 5.08 turns per inch), at 6400 steps per revolution, your machine is going to be looking for 32512 steps per unit (inch) if direct driven.... if you have belt drives or gearboxes etc to increase torque then that would add to that number by the ratio...
What is your X,Y,Z and A axis drive mechanism.... what is its pitch..... does it have intermediate belt drives or gearboxes and what are their ratio?
Postby Nickschneiders » Wed Jan 08, 2020 8:52 pm
I did some tests and I think it was software related on the g-code side. I am using Aspire and used the UCCNC postprocessor and I think it generated millimeter G-Code. I switched the postprocessor to Mach 3 (inch) and now it's cutting fine.
Nickschneiders
