Hi, I am not suggesting that there is anything at all wrong with the macros.
What I am trying to determine is:
Being: 1 of the three inputs x1, x10 or x100 must see a state change as stated by cncdrive ....
If all three inputs x1, x10 or x100 were OFF when the SW started, and THEN one of them received a signal from the pendant when it was enabled, would it work that way ?
The OFF position of the AXIS switch would disable/interrupt the power to the INC switch, so all INC inputs would be OFF.
There would be a state change at an AXIS input as well as at one of the INC inputs anytime the AXIS switch was then moved from the OFF position to select an axis.
I'd just like to know if this scenario would basically do the same as the PWM method suggested by cncdrive.
Thanks very much for your help,
Russ
