MODBUSEZ Plugin
Re: MODBUSEZ Plugin
Postby mrping » Sun Dec 16, 2018 9:21 am
it is version 49...
mrping
Re: MODBUSEZ Plugin
Postby mrping » Sun Dec 16, 2018 9:28 am
The modbusez was old though upgrading it now
mrping
Re: MODBUSEZ Plugin
Postby mrping » Sun Dec 16, 2018 9:39 am
Im running 49 version now with modbusez version 16. It is not saving my config, its reset every time I start UCCNC.
mrping
Re: MODBUSEZ Plugin
Postby mrping » Sun Dec 16, 2018 10:02 am
changed min RPM to like 6000 and it worked (my spindle is 200 - 6000 though).
But the same thing occurs, spindle starts, stops in the middle of loading and then starts spinning again. No commands works.
Maybe it uses other registers ?
mrping
Re: MODBUSEZ Plugin
Postby mrping » Sun Dec 16, 2018 10:16 am
spindle cw seems to be 0001
spindle ccw seems to be 0002
spindle off 0006
frequence is unknown
mrping
Re: MODBUSEZ Plugin
Postby Dan911 » Sun Dec 16, 2018 12:17 pm
mrping does this use a Modbus protocol for serial communication??? If not ModbusEZ isn't going to work out of the box. The manual gives no info.
Re: MODBUSEZ Plugin
Postby mrping » Sun Dec 16, 2018 1:08 pm
Yes and CW, CCW, stop works with modbusez plugin.
its only the rpm left.
Can i read it out someway ?
mrping
Re: MODBUSEZ Plugin
Postby mrping » Sun Dec 16, 2018 1:10 pm
See pic
mrping
Re: MODBUSEZ Plugin
Postby mrping » Sun Dec 16, 2018 2:09 pm
mrping
Re: MODBUSEZ Plugin
Postby Dan911 » Sun Dec 16, 2018 8:31 pm
Yes with a Serial Monitor, you can try the free trial 1 here.>>> https://www.eltima.com/products/serial-port-monitor/
ModbusEZ divides you Max HZ with your max RPM and sends results in a high low byte in hex to register you input in settings.
For example with your settings, you set your RPM to 3000 it's going to send 25HZ (hex 00FA) or (09c4) depending on frequency resolution setting. Don't have time today but will take a better look at your manual tomorrow and see if I can help.
Users browsing this forum: No registered users and 24 guests
