Gcode Unit Converter Plugin
Re: Gcode Unit Converter Plugin
Postby Dan911 » Wed Sep 26, 2018 2:43 am
Here ya go Terry, tab index in order and add # lines.
if you just want to add # lines and nothing else check scale with a scale factor of 1. Same for remove just don't check add line #.
Unit Converter4.zip
Postby Dan911 » Wed Sep 26, 2018 10:24 pm
Hi all, I'm deleting this plugin from the Tool Box section of this forum since this section is for working macro's, plugins and wizards. The original upload was(mm to inch and inch to mm) but adding the new features per request I was notified of some issues. My intent with Scaling was to have no affect on Z, but some Gcode variables can be used differently such as "R" with a canned cycle or G2 and G3.
I will make available to test and try in the Conversational Wizards section of this forum.
Return to UCCNC TOOL BOX
Users browsing this forum: Google [Bot] and 0 guests
