Hi all
i'm new of this forum. I install UCCNC n(1.2048) with HY12 (1.0012) and XHC(1.4) plugins on a core duo 1.8Mhz with UC400eth
All go well if i use Mdi Command
The pendant instead give me problem with JOG and button go well.
JOG problem.. selected the axis:
- in continous set don't give any movemet and HB04 Display don't move
- MPG COnt set don't give any movemet and HB04 Display go up and down correctly
- MPG Single set give a strange movement (a few foward a few backward when i went only foward or only backward) and HB04 Display go up and down correctly
- MPG Multi set go correctly Bacward (HB04 Display too) and give the same instable movement of single set when i go forward (hb04 Display go well)
please can you help me?
thanks in advance
Flavio
