I'll have to check the version when I get home, but one of the latest test versions.
I set the both error tolerances to .25, and it made no difference. Ran the same as if it was .01.
Obviously needs Balazs to check it out
Yes, we already learnt a lot from developing the UCCNC and I think I have mentioned before that we see the limits of the current trajectory planner algorithm and we already figured and thought out a different one which could work even more optimal than the current one and would have less limitations and could also implement S-curve acceleration. The current one could not implement S-curving.
So, yes, we can resolve the limitation of this example code the same time when we will implement the S-curve acceleration, because both require a new and different algorithm.
Users browsing this forum: No registered users and 37 guests
