Make TextFields on the screen ReadOnly
Postby shad » Tue Sep 20, 2016 8:20 pm
Is it possible to add ReadOnly properties for the textFields?
And it's will be great to add Auto-Calculator for input new value to the DRO by mouse click or from touch screen monitors.
Thank you!
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
http://neuroncnc.com/
shad
Re: Make TextFields on the screen ReadOnly
Postby ger21 » Tue Sep 20, 2016 9:36 pm
If there was a "SetLabel" function, you could use a Label. I've done this in Mach3.
Postby cncdrive » Tue Sep 20, 2016 9:45 pm
Andrey,
Yes, you can set the textfield's type property to showfieldnb or showfield then it will be read only.
What do you mean by Auto-Calculator?
I'm not sure if you ment that, but there is an option (checkbox) in the Appearance menu to auto-validate the DROs always when leaving the textfield, then no Enter keyboard key press is required.
Postby shad » Tue Sep 20, 2016 10:04 pm
Thank you for information about textfields. I will try.
No, I am about pop up MDI window for input like calculator. For example when you click on the DRO.
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
shad
Postby shad » Tue Sep 20, 2016 10:06 pm
showfieldnb property working very well.
Thank you!
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
shad
Return to Custom Screensets
