Reducing main screen codeview area height
Postby merrick » Wed Aug 23, 2017 4:24 pm
The on screen editor disables changing the height of the codeview area. I need to reduce its height a little to make room for other stuffs. Any suggestion? Thanks.
merrick
Re: Reducing main screen codeview area height
Postby ger21 » Wed Aug 23, 2017 5:16 pm
The height is dictated by the font size. I think the number of rows displayed is fixed, and larger fonts give you a taller window, smaller fonts a shorter window.
Postby cncdrive » Wed Aug 23, 2017 5:31 pm
Yes, exactly as Gerry said. The number of rows is fixed and so the smaller Font size creates a lower height window. Other than that you can't change the height of the codeviewer, because the (if I recall 16 rows) with the setup Font size defines the height.
Return to Custom Screensets
