Custom ATC Screen Set - Need Someone to Modify
Postby Meyer Woodworks » Mon Oct 16, 2023 1:57 pm
Hello, I recently added a Rapidchange ATC. I would like to use the original screen set but have someone slightly modify it.
The default 2019 uses a super slick "Tool 0 | Tool 1" with a change-tool button that I would like to add to the original screen set. A park 3 position would be nice as well, but not mandatory.
Meyer Woodworks
Re: Custom ATC Screen Set - Need Someone to Modify
Postby dezsoe » Mon Oct 16, 2023 9:16 pm
What do you mean by that "Tool 0 | Tool 1"? If you mean the current tool - new tool - change tool trio then just wait for the next release, the old screenset (Defaultscreenset) will have these fields and the button.
change tool on defaultscreenset 2116.png (15.63 KiB) Viewed 1555 times
You can find the Park3 button on the probe screen. It was removed when the jog safe probe (JSP) button was added. (Of course, you can modify the screenset as you like it: put back the Park3 instead of the JSP or make the buttons a bit narrow to fit the Park3, etc.)
Return to Custom Screensets
