Limit Switches
Limit Switches
Postby Edi_48 » Sat Nov 12, 2022 3:41 pm
Hello Gerry
On Ran's page, in the Machine column, there is a Crazy values question where can I delete them?
Where can I set my meshes to zero point?
Why don't my limit switches react, they are all connected in series, when I operate them manually I see them in Diagnostic. The machine moves fully onto the limit switches and over them. I now have
4 broken limit switches.
Hilton
Edi_48
Re: Limit Switches
Postby ger21 » Sat Nov 12, 2022 4:09 pm
Can you post a screen shot? Not sure what you are talking about.
Re: Limit Switches
Postby Edi_48 » Sun Nov 13, 2022 10:17 am
Wie kann ich PNG Dateien hochladen
Edi_48
Re: Limit Switches
Postby thegreatwaldo » Sun Nov 13, 2022 10:57 am
Speichern als .jpg in windows photo oder paint. Lg Andrew
thegreatwaldo
Re: Limit Switches
Postby Edi_48 » Sun Nov 13, 2022 3:30 pm
Meine Postscreen
UCCNC software 13.11.2022 10_39_05.tif
UCCNC software 13.11.2022 10_39_05.tif (480.83 KiB) Viewed 4479 times
Edi_48
Re: Limit Switches
Postby Edi_48 » Sun Nov 13, 2022 3:33 pm
Teil 2
Edi_48
Re: Limit Switches
Postby fsli » Sun Nov 13, 2022 9:50 pm
If all your home and limit switches are wired together, then you need to set the Limit+ Pin and Limit- Pin settings to match the Home Pin settings.
If your limit switches are connected to a different input pin than the Home switch, then you need to set the Limit+ Pin and Limit- Pin to the correct input pin values.
Frank
fsli
Re: Limit Switches
Postby Edi_48 » Sat Nov 26, 2022 3:24 pm
Hallo
Ich habe neue PNP Sensoren gekauft und wie im Handbuch UCSB Seite 9 Absatz. 5.2.12 angeschlossen . Im Axis Menü Home Pin 10 Port 1 Haken gesetzt.
Wenn ich jetzt manuell meine Achsen Verfahre sehe ich jetzt das meine Sensoren Ansprechen
Aber die Maschine fährt weiter. Softlimits eingeschaltet.
Wo ist mein Fehler?
Hilton
Edi_48
Return to Custom Screensets
