Screenssets updated with V2031 (;-)
Re: Screenssets updated with V2031 (;-)
Postby ger21 » Sat Feb 04, 2017 12:23 am
Blinking LED's and Sliders. :lol:
Postby cncdrive » Sat Feb 04, 2017 2:19 am
Yep, the blinking LEDs parameter is the main reason why you immediately can't go back with the screenset to prior versions as soon as you save the screenset,
because the AddLED function has one more parameter now which defines if the LED is blik type.
So, when you save the screenset with V1.2031 then the new function prototype will be used with that one more parameter which earlier software versions does not understand and will give you a screenset error.
The Addslider function will only give a screenset error if you place a slider on the screen and save it, because the sliders were not known in previous software versions, that screen object was added only in version 1.2031.
Return to Custom Screensets
