2017 Screenset released
Re: 2017 Screenset released
Postby Makingtoothpicks » Sat Mar 18, 2017 8:58 am
Found the setting and fixed it.
Thank you
Don
Makingtoothpicks
Postby QuebecCNC » Sat Mar 25, 2017 1:24 pm
Just wanted to know what is the latest version. Is it compatible with release 1.2036?
Thank you
QuebecCNC
Postby ger21 » Sat Mar 25, 2017 6:11 pm
In most cases (if not all), newer versions of UCCNC should still work with whatever version of the screenset that you have.
If new features are added to UCCNC, then they won't be available in the 2017 Screenset until I add them.
Here's where it gets a little tricky.
If I add the new feature, then the screen won't work unless you update to the latest version of UCCNC.
1.2036 added a setting for arc tolerance.
I have a new version of the screen that supports it, but I haven't released it yet, as it requires 1.2036 to work.
I'll send out the link to all customers right now.
Postby Mogal » Wed Mar 29, 2017 5:17 am
Just made my purchase tonight.
Will be the new owner of a UC300ETH with the UCCNC software, and Gerry's screen set!
Looking forward to retiring the ol' PP port!
Would like to request the addition of that 'Verify' Macro ;)
Mogal
Postby toremick » Thu May 04, 2017 4:04 pm
Hi all,
This is my first post here.
Think i have gotten bit by the uccnc bug. Just bought the uc400eth, uccnc software and now this screenset.
Everything just looks so promising! :)
toremick
Postby QuebecCNC » Tue May 09, 2017 4:26 pm
ger21,
Can you have a look? viewtopic.php?f=4&t=559
QuebecCNC
Postby ger21 » Tue May 09, 2017 5:26 pm
It shouldn't have anything to do with the screenset. The screenset just has a button with the number of the calibrate function.
I've never used the calibrate function myself.
Why not just do the math and enter the number of steps?
Postby QuebecCNC » Tue May 09, 2017 5:28 pm
I honestly don't quite know how to do this...
QuebecCNC
Postby alex_s » Thu May 18, 2017 7:54 pm
Hello Ger21,
will you add the new DTG feature to the screenset ? ( maybe switchable with the actual DRO)
BR
Alex
alex_s
Postby ger21 » Thu May 18, 2017 8:01 pm
While I was working on adding new features last night, I don't plan on adding the Distance to go. Not sure how to go about it, unless I took the same route as CNC Drive.
But I don't think that most user's would want or need them?
I just had an idea, though, so I'll be exploring some new options.
Return to Custom Screensets
