Robertspark wrote:you can run the job in offline mode....
Won't give you the time though
Robertspark wrote:What governs the speed of simulation?
trying to think out of the box....
Robertspark wrote:make the machine offline,
Would it be possible to change the axis units via a macro by say a factor of 10 (reduce by 10 [adjustable]),
run the programme with a timer enabled, recording run time in mSec.
log the time at the end of the run cycle
multiply the time by 10 [to give a rough estimate of the simulation run time]
change all axis back to default setting
put the machine back on line.
(note, apply the axis settings changes, but don't save them so that the change is not perminant, so if you have a power down or PC crash, under restart the original axis settings are retained / reloaded)
