2017 screenset with axbb ?
Postby thegreatwaldo » Sun Nov 24, 2019 2:57 pm
Hi Ger.
Will there be an update for the 2017 screenset to work with the axbb controller?
Cheers.
Andrew
thegreatwaldo
Re: 2017 screenset with axbb ?
Postby ger21 » Sun Nov 24, 2019 3:12 pm
Yes, but not until sometime after an official (non test version) release of UCCNC that supports it.+
Attached is a file that will allow you to use the AXBB with the current 2017 Screen. The diagnostics LED's are wrong, and it doesn't support any features after 1.2047, but it'll work.
2017 - AXBB.zip
(165.85 KiB) Downloaded 813 times
Postby thegreatwaldo » Sun Nov 24, 2019 3:35 pm
Thanks Ger.
It'll be a while till I get my new machine up and running, but it's good. To know that you'll be supporting the Axbb.
Cheers.
Andrew
thegreatwaldo
Postby ger21 » Sun Nov 24, 2019 5:01 pm
I kinda have to, since I own one. :D
Postby thegreatwaldo » Sun Nov 24, 2019 8:14 pm
Ah!!
Good point I suppose. Have you got it up and running ? and is it ok ? if you don't mind me asking.
Cheers
Andrew
thegreatwaldo
Postby ger21 » Mon Nov 25, 2019 12:59 am
No, it's still sitting in the drawer. I bought it specifically for testing macros while working on the screenset. I finally have the majority of the screen done, and hopefully will start working on the macros soon. Probably early next year.
I currently don't have any plans to use it on a machine right now.
Postby Owlwood » Tue Aug 10, 2021 2:10 pm
Hi Ger
Has there been any update on your 2017 screenset?
Can it be used with AXBB-E with 1.21 firmware
Cheers
Ben
Owlwood
Return to Custom Screensets
