help! screenset error during editing custom screenset
Posted: Mon Dec 24, 2018 10:06 am
Help.... suggestions please.....
Basically I removed everything off the front screenset and have added new objects.
I didn't edit any combobox items so they should be fine and I think those are the only things with an "index"
- Code: Select all
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
at UCCNC.GUI.Leavetextfieldswithoutvalidation()
at UCCNC.GUI.gl_main_mousedown(Object sender, MouseEventArgs e)
at System.Windows.Forms.Control.OnMouseDown(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.UserControl.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.3260.0 built by: NET472REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
UCCNC
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/UCCNC1/UCCNC.exe
Win32 Version: 4.7.3221.0 built by: NET472REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 4.7.3190.0 built by: NET472REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32 Version: 4.7.3056.0 built by: NET472REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
OpenTK
Assembly Version: 1.1.0.0
Win32 Version: 1.1.1664.6217
CodeBase: file:///C:/UCCNC1/OpenTK.DLL
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
蕾ᴋ瑾勻Ꮷ烚▥
Assembly Version: 0.0.65535.65535
OpenTK.GLControl
CodeBase: file:///C:/UCCNC1/OpenTK.GLControl.DLL
OpenTK.Compatibility
CodeBase: file:///C:/UCCNC1/OpenTK.Compatibility.DLL
ILCalc
Assembly Version: 0.9.7.5
a4aczha4
Assembly Version: 0.0.0.0
Plugininterface
CodeBase: file:///C:/UCCNC1/Plugininterface.DLL
AutoLevelerCA
CodeBase: file:///C:/UCCNC1/Plugins/AutoLevelerCA.dll
Console
CodeBase: file:///C:/UCCNC1/Plugins/Console.dll
Debugger
CodeBase: file:///C:/UCCNC1/Plugins/Debugger.dll
Diagnostics
CodeBase: file:///C:/UCCNC1/Plugins/Diagnostics.dll
Laserengrave
CodeBase: file:///C:/UCCNC1/Plugins/Laserengrave.dll
Lubricator
CodeBase: file:///C:/UCCNC1/Plugins/Lubricator.dll
Modbusmaster
CodeBase: file:///C:/UCCNC1/Plugins/Modbusmaster.dll
Neuron
CodeBase: file:///C:/UCCNC1/Plugins/Neuron.dll
Pinout
Assembly Version: 2.1.0.0
Win32 Version: 2.1.0.0
CodeBase: file:///C:/UCCNC1/Plugins/Pinout.dll
Plugintest
CodeBase: file:///C:/UCCNC1/Plugins/Plugintest.dll
Printer3D
CodeBase: file:///C:/UCCNC1/Plugins/Printer3D.dll
Profiler
CodeBase: file:///C:/UCCNC1/Plugins/Profiler.dll
Scope
CodeBase: file:///C:/UCCNC1/Plugins/Scope.dll
UCCAM
CodeBase: file:///C:/UCCNC1/Plugins/UCCAM.dll
UCCNC_OSK
Assembly Version: 1.7.3.0
Win32 Version: 1.7.3.0
CodeBase: file:///C:/UCCNC1/Plugins/UCCNC_OSK.dll
UCR200Plugin
CodeBase: file:///C:/UCCNC1/Plugins/UCR200Plugin.dll
UCR201Plugin
CodeBase: file:///C:/UCCNC1/Plugins/UCR201Plugin.dll
Webcamera
CodeBase: file:///C:/UCCNC1/Plugins/Webcamera.dll
Xbox360controller
CodeBase: file:///C:/UCCNC1/Plugins/Xbox360controller.dll
XHC-HB04_pendant
CodeBase: file:///C:/UCCNC1/Plugins/XHC-HB04_pendant.dll
ZedGraph
Assembly Version: 5.1.5.28844
Win32 Version: 5.1.5.28844
CodeBase: file:///C:/UCCNC1/ZedGraph.DLL
Accessibility
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
Microsoft.CSharp
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.CSharp/v4.0_4.0.0.0__b03f5f7f11d50a3a/Microsoft.CSharp.dll
System.Dynamic
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Dynamic/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Dynamic.dll
Anonymously Hosted DynamicMethods Assembly
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll
r3lsunyc
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
