New button added. Now what?
Postby PillyWilly » Sat Mar 17, 2018 10:57 am
Hi All
Okay, I figured out how to add a new button to my "RUN" screen.
How do I configure this new button to run my custon M code?
Regards
Jan
PillyWilly
Re: New button added. Now what?
Postby ger21 » Sat Mar 17, 2018 11:15 am
Make the button number the same as the macro number.
It should be between 20000 and 20999.
Postby PillyWilly » Sat Mar 17, 2018 2:17 pm
ger21 wrote:Make the button number the same as the macro number.
Thanks, helpfull info.
Now I get a File:/Profiles/Macro_Default\M20000.txt Could not read!
All this M20000.txt contains is:
exec.Setoutpin(1,1);
for triggering Pin 1 on Port 1 on my UB1
Regards
PillyWilly
Postby dezsoe » Sat Mar 17, 2018 2:21 pm
Did you save M20000.txt in the folder /Profiles/Macro_Default? UCCNC looks for it there.
Postby PillyWilly » Sat Mar 17, 2018 2:23 pm
dezsoe wrote:Did you save M20000.txt in the folder /Profiles/Macro_Default? UCCNC looks for it there.
Yes, it is there.
PillyWilly
Postby dezsoe » Sat Mar 17, 2018 2:49 pm
Interesting... If you type M20000 in MDI, does it run?
Postby ger21 » Sat Mar 17, 2018 2:54 pm
Are you using the default profile, or a different one?
Postby PillyWilly » Sat Mar 17, 2018 2:58 pm
Yes, it is there.
No, sorry, the file was placed in the Contents folder.
All fine now
PillyWilly
Postby dezsoe » Sat Mar 17, 2018 3:04 pm
OK! :)
Postby Dan911 » Sat Mar 17, 2018 4:58 pm
I written a plugin that you can use to turn pin on/off in any port with E-stop enabled. Use button, mdi or hot-key. Need the newest UCCNC version.
PortPins.zip
(4.96 KiB) Downloaded 106 times
Return to Custom Screensets
