UCCNC Screen Editor Web App
Re: UCCNC Screen Editor Web App
Postby zerodivide » Mon Mar 27, 2023 3:10 am
Gosh, I can't believe it has been 2 years since I first made it available!
Time flies when you are old! :(
Any way I needed to make some changes to my own screenset and have also made some quick modifications revolving around bug fixes, better source screenset parsing and copying capabilities.
Now all of the functionality built-in to UCCNC is supporters and more.
Such as mass-copying elements between controllers, and mass-delete.
Screensets now don't suffer from element ordering issues. And from my testing it is possible to completely remove all elements and recreate a screenset from scratch.
Let me know if you see any issues or bugs.
zerodivide
Postby Meyer Woodworks » Mon Oct 16, 2023 2:46 pm
Would someone be able to help edit and make a custom screen set for me? Nothing crazy, I just want to use the original screen set but add the Tool Change button that's on the default 2019 screen set.
Meyer Woodworks
Postby X3msnake » Thu Sep 12, 2024 6:20 pm
@zerodivide
Hope since the last time you posted about the donation button more people have come forward. Personally i only saw the donation button today when i tried the web app.
Would be cool if you could add the donate button to the github also and add a link to the github on the webpage to link the two. I have sent you a little something as a token of my appreciation.
Thanks for the effort and thanks for sharing Master
X3msnake
Postby cncdrive » Thu Sep 12, 2024 6:48 pm
You could also place a donation button in this forum thread. (I'm not sure though if it is possible to integrate?!)
Postby Ukendt » Sat Dec 14, 2024 7:40 pm
Hi , ive got my hands on a custom screenset made for the UC300ETH-UB1 , but i am on XABB-E controller ! ive been tinkering with this editor , and tryed to copy all the content from UC300 screenset to XABB , but it will not work at all . Was hoping that it could be done via copying the elements (all off em) to XABB , seems to copy fine , but when selecting the screenset in UCCNC it loads for a bit and i get alarm sound and then nothing more happens . I have a hard time trying to figure this out , perhaps one of you guys can help ? its way to complex for me to do on my own . Its very nice to have an option to remake an screenset !
Kind regards
Ukendt
Ukendt
Postby wazza187 » Sat Dec 21, 2024 10:17 am
Firstly, great utility!
I encountered an issue with resizing my screensets. The resulting files fail to open and UCCNC fails silently (no error, just doesnt open).
I tracked it down to the resizing option adding decimal places to the item dimensions, which UCCNC does not seem to like.
An easy workaround is to open the resultant screenset file in Notepad++, and use 'search and replace' with 'regular expression' mode activated, search for
\.\d+
and replace with blank.
wazza187
Postby Moodivarius » Thu Feb 13, 2025 5:39 am
Thanks for all the hard work.
I tried it tonight. Edited background pic, deleted some unnecessary buttons, & shifted a few around, for my needs.
Works great.
Scott
Moodivarius
Postby Delco » Sun Feb 16, 2025 2:26 am
Hi , just found your editor , are there any tutorials or youtube videos of its use ? ,, trying to change a screenset from UB1 to 5ltp but the copy elements screen does not seem to work or I am using it totally wrong.
Anyway thanks for the resource , hopefully someone who uses it will chime in
Delco
Postby ger21 » Mon Feb 17, 2025 3:05 pm
If it's a screen specifically for the UB1, and no other controllers, open it in Notepad, Find and replace UC300ETH_UB1 with UC300ETH_5LPT.
Done.
Postby Corwax » Thu Apr 17, 2025 9:15 pm
Hi there!
Kinda issue... After opening C:\UCCNC\Screens\Default2019.ssf and pointing to C:\UCCNC\Flashscreen\BMP\Default2019\ I've got no pics loaded and messages "Parse errors; Unable to load BMP/Default2019/Zeroallbutton_up.png A requested file or directory could not be found at the time an operation was processed." and all other BMPs
It seems i've turned wrong way...
Any advices appreciated,
thx
Corwax
Return to Custom Screensets
