Hello! Can we change the jog step distance for the distance buttons, for example now this is 0.001, 0.01, 0.1 or 1.00 Units. Can we set 0.1,1,5,10 units? Thank you!
Yes. You have to make your own buttons with macros to write new value to field 2027 (JogStepDistance). You also have to call AS3Jog.Validatefield(2027); after writing. You can also put it in your plugin and then you don't have to write macros.
Yes, it's worked if I am after then UCCNC started load and start program. But if I am not load and run program the value of speed is 6 mm / min. Can I change this default value? I tried to write a new value in the field but without result. The jog speed still same.
