Poor quality v-carve
Re: Poor quality v-carve
Postby ger21 » Sat Oct 01, 2016 6:43 pm
Is this the best that I can expect from this machine?
Hard to say. There are a lot of things that can affect the cut quality.
But the X Carve is not a very rigid machine.
If you reduce the feedrate by 50%, is the quality better?
Or, try reducing the depth per pass in V Carve by 50% and see if it helps.
If the problem is the machine flexing, then reducing the loads can improve quality.
Postby jtb223 » Mon Oct 03, 2016 1:41 am
Gerry,
I slowed things down considerably and the quality of cut is better but I'm also realizing the limitations of this machine. I guess I'll just have to build a more rigid machine.
Thanks for the input,
Jim
jtb223
Postby Battwell » Sun Feb 12, 2017 11:03 pm
that file cuts way nicer with a 90 degree bit than 60 degree by the way. - dont know why but edges against the lines stay straight.
Uc300eth on router and mill
