6 Axis Mill / Turn Woodworking machine
Postby MRob » Wed Aug 14, 2024 1:41 pm
Enclosure open as I was doing a rebuilt of the lathe knives. Continuous turn functionality from the little controller on the table right of the screen. Yaskawa servos on YZA (the important ones), cheap steppers cover elsewhere. Black parts in the photo (orange in model) are 3d printed, if they need to be strong they are printed as shells and filled with epoxy granite. All other parts milled on my 1st CNC machine. MDF is a PITA to work with, but most the important parts here were milled rough, soaked in epoxy, and then finished. In retrospect I should have just found a better material :roll:.
Crazy amount of work in this!! But it works.... very well :D
(images cut off to the right, right click open new tab if you want to see full)
MRob
Re: 6 Axis Mill / Turn Woodworking machine
Postby Battwell » Tue Aug 27, 2024 8:04 pm
what are the 2 pointy black boxes on top?
i almost finished converting a very heavy copy lathe to similar spec usage.
annoyingly another machine came in and blocked the space right in front of it for the last 6 years.
Postby MRob » Sun Sep 29, 2024 11:41 am
Very limited space behind the spindle, I didnt want anything back there that needed servicing, and the X axis is tiny, so I made a driven lead screw nut (nut turns, not the screw). The lead screw then raises up, into the space of the pointy box, you can see better if you open the design assembly picture. Belt transmits from the driven nut, to the little shafts on the right, which goes down to two small stepper motors. It's a bit of a crazy setup, but I was trying to make everything as compact as possible. Good luck with your project!
MRob
