Page 2 of 2
Re: 3500x2200mm CNC Build with UCCNC
PostPosted: Mon May 25, 2020 5:17 pm
by dezsoe
You can connect buttons to inputs and set them as input triggers to activate buttons like Cycle start. It is also possible to automate the startup, however I do not recommend it, because it is unsafe to start movements without user interaction.
PostPosted: Mon May 25, 2020 7:50 pm
by RRocadas
dezsoe wrote:You can connect buttons to inputs and set them as input triggers to activate buttons like Cycle start. It is also possible to automate the startup, however I do not recommend it, because it is unsafe to start movements without user interaction.
Ok thank you.
I have passed from grbl to UCCNC and it's amazing all possibilities!!!
So i can wire a button for example to a isolated input I4+ and power input 24v+ and tell in uccnc interface that Pin I4 is to cycle start?
thank you very much for the help
PostPosted: Mon May 25, 2020 9:16 pm
by dezsoe
Yes, exactly.
PostPosted: Mon May 25, 2020 10:42 pm
by RRocadas
dezsoe wrote:Yes, exactly.
Thank you very much.
PostPosted: Mon May 25, 2020 11:25 pm
by RRocadas
Here one of the test's at 10000mm/min
PostPosted: Fri May 29, 2020 11:41 am
by RRocadas
Z axis to start.
PostPosted: Mon Jun 22, 2020 7:35 pm
by RRocadas
Just came back with ore time and i'm finishing z axis now.
PostPosted: Sat Jul 18, 2020 1:36 am
by maycatcnc
thank you for your help i guess i will need for this.
PostPosted: Mon Sep 21, 2020 6:44 pm
by RRocadas
Hi everybody
THanks to all who have been helping me.
Here are the first test of movements.
