Ceiling WalterLamp.
Ceiling WalterLamp.
Postby manufv » Tue Feb 25, 2020 4:41 pm
Hi, I'm happy to share my realisation of a WalterLamp.
I do it to set as a lamp on the ceilling of a hall.
It's 45cm high, pinewood 18mm.
With the bulb of 25w, the design beams a cool light.
G-code build with VcarveDesktop.
Cut with UCCNC 1.2111 on a Stepcraft D840, Spindle HF500.
Credit & design to esparapse https://www.instructables.com/id/Cnc-Wood-SculptureLamp/
walterLamp Mount
walterLamp Vcarve Body
walterLam Vcarve Gear Top
walterLamp Cutted
walterLamp cutting
walterLampLight
manufv
Re: Ceiling WalterLamp.
Postby Robertspark » Tue Feb 25, 2020 8:17 pm
Nice
Postby ger21 » Wed Feb 26, 2020 4:17 am
Nice work.
A little tip - The pieces would be much stronger if the grain direction was rotated 90°
Postby manufv » Wed Feb 26, 2020 12:18 pm
ger21 wrote:Nice work.
thanks you.
You are right, I'll make a second as you advice.
manufv
Postby Battwell » Fri Feb 28, 2020 12:19 pm
very nice design. agree with ger re grain direction.
Postby Tweakie.CNC » Sat Mar 07, 2020 10:19 am
Excellent work manufv.
Tweakie.CNC
