Highly Modified Taig with R8 Spindle/PDB and DMM 750W Servo
Just realized I've never posted any of my vids here. Guess because I suck at making videos, but here's my current "Work in Progress" mill. The spindle was completely DIY by a buddy including the shaft made from scratch and ground on the bearings. The power drawbar, motor mounts and various accessories designed and made by myself (and input from another buddy who also happens to make the heavy duty frames). Next up we are working on linear rails....then it will be Taig no more....all DIY. Will be adding DMM servos to the axis and finally working on our ATC project (which is still in a bit of flux on the final design and style).
Just posting a link to my channel as it shows the various stages of change with the machine and performance with the mods. Need to get back into some videos as I'd since added a direct spindle encoder and would like to see how much improvements that makes with the DMM servo motor. Also added a foot pedal finally for my PDB using a relay out originally meant for my original spindle motor with just on/off control. Glad I kept it, as now using it active low, I just plug in my foot pedal and PDB solenoid into the plug of that, no worries about stepping on it while in spindle is in operation. Also still have a manual button on the solenoid for changing tools while the system isn't up and running (tweaking spindle and such).
https://www.youtube.com/channel/UCFCKp9J-io2nqvfoKwSETFQ?view_as=subscriber
Here is one vid showing the first run of the DMM 750w servo without spindle feedback (just it's own controller feedback). I've found since adding he direct spindle encoder, analog speed mode was greatly improved. Stays within 1 RPM unloaded and haven't had much chance to mill lately to check loaded. But from past PID feedback experience with a different motor, seemed to keep it within 100 RPM loaded.
Ok, no idea why the embed code isn't working, so here is just a link https://www.youtube.com/watch?v=GfRMmgX2-38
