AvB projects
AvB projects
Postby AvB » Wed Jan 16, 2019 8:14 am
Hi - I saw this forum section for posting stuff we've made, so I thought I'd post some pictures. I am not an experienced CNC machinist. I bought my mill about 5 years ago, to produce model aircraft moulds. A bunch of us have been heavily into slope soaring and dynamic soaring gliders. We got into building our own planes and making moulds, and eventually we wanted to get CNC cut moulds. It was impossible to find anyone to cut moulds for us at a reasonable price so after several years I had a mid life crisis and instead of buying a new car I bought a CNC machine. Mostly we cut the moulds out of acrylic based solid benchtop material such as Corian. We want very high accuracy of the aerofoil shape, and very sharp corners particularly in the leading edges.
AvB
Re: AvB projects
Postby AvB » Wed Jan 16, 2019 8:17 am
A few more:
AvB
Re: AvB projects
Postby cncdrive » Wed Jan 16, 2019 2:10 pm
Nice. Thanks for sharing the pics. :)
Re: AvB projects
Postby AvB » Wed Jan 16, 2019 8:44 pm
Hey how do you edit your posts? I can't see an edit button anywhere. Thanks.
Andrew
AvB
Re: AvB projects
Postby cncdrive » Wed Jan 16, 2019 9:50 pm
Editing is only possible until somebody posts, otherwise if you could change your posts even after somebody replied then the answer posts and the discussion could loose their meanings.
Re: AvB projects
Postby beefy » Thu Jan 17, 2019 12:42 am
cncdrive wrote:Editing is only possible until somebody posts, otherwise if you could change your posts even after somebody replied then the answer posts and the discussion could loose their meanings.
Ah, so that's how it works. I thought it was simply a timeout, but the above makes a lot more sense. I'll be more careful now before I click the "submit" button because someone could post immediately after I post, and many times I read my post after submitting and realise a typo, or want to add something, etc. Just did it with this one :lol:
Keith.
beefy
Re: AvB projects
Postby AvB » Thu Jan 17, 2019 11:00 pm
No, that's incorrect - it doesn't allow editing even immediately after posting, before anyone else has posted.
I started this new thread and wanted to edit it immediately but there's no option to edit.
viewtopic.php?f=15&t=1744
Cheers,
Andrew
AvB
Re: AvB projects
Postby cncdrive » Thu Jan 17, 2019 11:07 pm
Maybe there is also a time limit, I'm not sure.
Dezsoe, please check it out. Thanks.
Re: AvB projects
Postby dezsoe » Fri Jan 18, 2019 6:40 am
There is a 30 minutes limit set to edit or delete you own post.
Re: AvB projects
Postby AvB » Sun Jan 20, 2019 4:14 am
Unfortunately this wasn't working. I tried to edit immediately after posting. I will try again with this reply.
AvB
