Arduino modbus control panel project
Re: Arduino modbus control panel project
Postby Battwell » Fri Sep 21, 2018 8:09 pm
analogs done- although after this video i changed spindle speed to be 50% to 150% (when i worked out the math for it)
ready to fit now :-)
im really happy with how its turned out.
il be using same panel on another machine shortly-as its so easy to do.
will also be using the arduino- redone as 2 wire modbus for distributed i/o around a big biesse machining centre running uccnc. (will be 8 arduino megas to handle all the i/o)
https://youtu.be/qJB7wor6OsY
Postby Battwell » Sun Sep 23, 2018 2:41 pm
i added macro blocking ( if a macro is running you cant start another instance of it. and cant run 2 macros at the same time.
also added timed buttons- which is pretty cool re use of buttons :-)
i also checked the runtime of my macroloop at less than 1 tick (1/1000,000 of a second) if it was idle- ie no buttons being pressed using the code ive put in uccnc toolbox so i know it will run blisteringly fast with nothing holding it back. thats faster than i got mach3 brains to work in the past.
https://youtu.be/Mxr_4iRQsdQ
