Battwell,
Thank you for your input! Is your CNC using ball screw or rack/pinion?
What is the axis travel for each revolution of you servo?
I will move 10 mm for each rev.
I can’t seem to be able to get more than 1000 rpm from my servos. In the data sheet it says that it has a max rpm of 2800. Could you guess why?
