Tablet for UCCNC UC-100
Postby Makingtoothpicks » Mon Dec 25, 2017 11:46 pm
Would this run Uccnc and Ger21 screen set
2016 NuVision 8-inch Full HD (1920 x 1200) IPS Touchscreen Tablet PC, Intel Atom Z3735F Quad-Core Processor, 2GB RAM, 32GB SSD eMMC, Webcam, WIFI, Windows 10, Silver
Makingtoothpicks
Re: Tablet for UCCNC UC-100
Postby dezsoe » Tue Dec 26, 2017 8:35 am
It can run UCCNC, but it has the standard tablet problem: there is only one USB port, which is the power input too. Some tablets can be used with special OTG cables, which provide USB port and charger in the same time, but not all can do it. Running from batteries is not a good practice, I think. (See this thread where I wrote some thoughts and my experience about using and testing tablets with UCCNC.)
Postby Robertspark » Tue Dec 26, 2017 8:46 am
https://www.amazon.com/NuVision-Touchsc ... B01H3B17R8
8" Full HD IPS touchscreen (1920 x 1200), 10-finger multi-touch support; Cameras: 2MP front, 5MP rear
Intel Atom Z3735F Quad-Core Processor 1.33 GHz with Intel Burst Technology up to 1.83 GHz; Intel HD Graphics with shared graphics memory
2GB DDR3L-RS 1333 MHz Memory, 32GB eMMC SSD storage. No Optical Drive
1xMicro SD, 802.11b/g/n (Miracast enabled), Bluetooth, 1 Micro USB (also used for power, cannot be used while charging), 1x Micro HDMI, 1x Headphone/Microphone combo; TPM 2.0, Dimension: 8.80 x 4.90 x 0.40 in (223.52 x 124.46 x 10.16 mm), Includes Micro USB to USB adapter.
Windows 10 Home, 32-bit; Battery life up to 6 hours. Weight 0.68lb. Color Silver
How do you intend to connect to the UC-100?
Note the bit above highlighted.
You are obviously free to do or try whatever you want but 8" would be a bit small for me (I had a 19" 4:3 monitor, and now use a 24" touchscreen with one of these: https://i.ebayimg.com/images/g/6LAAAOSw ... s-l300.jpg N3150 Dual Ethernet {with UC300eth + Neuron Plasma THC}, with wifi removed).
Wifi is not recommended for machine controlling applications (as the signal may be lost or affected by electrical noise). Would you drive your car on wifi / bluetooth?
Rob
UCCNC v1.2108 Macro Manual
Postby dezsoe » Tue Dec 26, 2017 9:20 am
He wants to use UC100, that's why I emphasized the USB problem. And yes, wifi is simply unuseable for the ETH controllers. I'm lucky to have a separate power input on my tablet, so I can use USB to ethernet converter or UC100. (In fact, I'm not lucky: I checked this before I bought my tablet. :))
Postby Makingtoothpicks » Fri Dec 29, 2017 5:53 pm
I am looking at running a tablet if I can find one that will work. I do not intend to use Wi-fi.
I will connect using usb. So I can see most are limited in usb ports. I will keep checking specs
and see waht I can find. I also would like the largest screen I could get.
Thank you for the replies
Don
Makingtoothpicks
