Re: Howto connect a Laser
Posted: Wed Dec 20, 2017 11:49 pm
ok lets clear things up ...
My laser is of the 2 pin kind which is pos and neg...
The board or boards are in theory all the same with options of 3 pin...12V, GND and PWM for the laser and a 2 pin for a laser stop confusing the issue about boards its not important guys its just a 2 pin connector 12v pos and neg
if you have a 2 pin it says to connect to the 12v Fan
I cannot supply a data sheet there is NOT one but the picture which is a different one i know but you can see the pins for a 12v laser conneted to the FAN yes it works the same end of
but enough of this its a 2 pin laser connection 12v pos and neg
right hope that clears a few things up and in case the next person ask...
its a chinky cheapo board ..yes it may have 3 pin and a 2 pin
BUT MINE IS a 2 PIN as per post number 1..
and i need to connect it to this some how ?
its a cnc4 you break out board
https://cnc4you.co.uk/resources/KK01.pdf
